Old 05-03-2010, 07:26 PM
Skint Skint is offline
Question Dunking the air filter
What is the procedure for oiling a new air filter ( Vans FAB) ?
Tim Bennett
RV7a
135
Polished aluminum
Painted wheelpants and fairings
Still have not developed a liking for fibreglass
2014 dues paid
Old 05-03-2010, 07:30 PM
Geico266's Avatar
Geico266 Geico266 is offline
I use a K&N cleaning kit and after the filter is dry I spray on the pink oil. No need to over spay it, just follow directions.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 05-03-2010, 08:13 PM
K&N offers a cleaning kit which includes the oil. The oil is in an aerosol can. You just spray the creases until they turn pink.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 05-03-2010, 08:39 PM
G-force's Avatar
G-force G-force is offline
The gauze in the K&N filters is cotton, so you need a cotton safe cleaner. You can't go wrong with the K&N brand. On the cheap, I have had success with a spray cleaner such as Simple Green or Fantastic. It needs to be something designed to cut grease and oil. Saturate, let stand 5 or so minuts, then rinse in as hot of water as you can. Don't use compressed air to clean it, you can blow holes in the cotton gauze. Let it air dry, then reoil. K&N oil comes in spray or a squeeze tube, it has a pink/red dye in it so you only need to apply enough to saturate the cotton to an even color of red/pink.
Mike Sumner
Castaic, Ca
Old 05-03-2010, 08:49 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Perhaps a dumb question, but since Van's FWF instructions don't say anything about oiling the NEW filter, is this something that needs to be done?
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 05-03-2010, 08:54 PM
rvbuilder2002's Avatar
New filters come pre-oiled ready to install.
Scott McDaniels
Hubbard, Oregon
Old 05-04-2010, 09:22 AM
JonJay's Avatar
JonJay JonJay is offline
Default Buy a spare filter.
When you are ready to clean, just install your spare pre-oiled filter. You can then clean your filter with appropriate cleaner (water soluable) and it will be dry and ready to oil the next time you do a filter change out. Rotating them like this makes it quick and easy and you dont need to wait for the filter to dry out.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 05-04-2010, 09:48 AM
FredMagare FredMagare is offline
I've enjoyed great success using this procedure for the K&N filter in my truck, recommend it to everyone, and will do the same when my aircraft is complete!
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 05-04-2010, 10:06 AM
noelf noelf is offline
Red face I was a bit overzealous when oiling...
...the cleaned filter in my O-360 carb'd engine. I did not realize it at the time, but I used too much of the K&N oil on the cleaned filter. The red oil dripped out of the aft FAB drip hole and put drops of the red fluid on different parts of the engine mount and nose wheel. I spent a lot of time looking for what I thought was a brake fluid leak. I could never figure out where the red fluid was coming from, only that it was on the aft side of the air box and lower portions of the engine mount.
At this point I had 2+ hours on the engine since the filter cleaning procedure, and for some reason I opened up the airbox for a look see. There was considerable air filter oil between the rubber seals of the filter and the fiberglass of the air box. I removed the filter, used an air hose to blow out the "excess" red oil, put it all back together, and now, no more red oil drips.
Old 05-04-2010, 10:24 AM
slyfox slyfox is offline
Don't put a bunch of oil on the filter, go as little as possible. THe more oil, the filter will restrict. On my 912uls I put to much oil on the filters and ended up with fouled plugs right off. I had to clean the filters again and the next time put only one drop of oil on each plete. So my advice, very little oil. I also have two filters, that way I can clean one and keep flying. Usually change them out at the 50hr oil change.
