05-03-2010, 06:14 PM
Need On Line Source For Tab Lock Washer
I can't seem to locate these. Tried ACS, MCMaster and an internet search. Found the manufacturers but no on-line source. These are often used on carbs and the tabs bend down/up to prevent the nut from turning and sometimes they have a tab with a hole for adding safety wire.
Thanks.
05-03-2010, 06:39 PM
Carb parts
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
05-03-2010, 08:16 PM
found them
Thanks for the link...wish I knew the part number.
I racked my brain and decided to search for "safety wire washer"...turns out ACS has them: http://www.aircraftspruce.com/catalo...ywirekits1.php
05-03-2010, 09:39 PM
Part #
I don't think the ones you found will work as the correct ones.
The part # is 78-A97
http://www.airpartshopping.com/produ...&categoryId=42
or
Search on Aircraft Spruce bring up this:
08-06852 78-A97-F VOLARE LK TAB WASHER $3.050
05-04-2010, 01:11 PM
Got it
Bobby,
Thanks for the help, I ordered some from Airparts.
Don
Reason: sp
05-04-2010, 01:26 PM
Spruce has em here.
AERO has em here.
05-04-2010, 02:00 PM
Now that we have sources, does anyone have a picture showing how they are supposed to be installed?
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
05-04-2010, 02:07 PM
Best I can do:
05-04-2010, 02:26 PM
Originally Posted by Brantel
Best I can do:
Thanks. I was thinking the tab washers that hold the FAB top plate to the carb, but I have wondered what would happen if I ever needed to replace that one too. My mistake.
Steve M.
Ellensburg WA
