Go Back   VAF Forums > RV Firewall Forward Section > Alternative Engines
Old 05-03-2010, 12:51 PM
Pilottonny Pilottonny is offline
Cool ??? "Reciprocating Aircraft Engine Type Designation System" ???
Hello Guys,
Lets see if the forums are faster than Google!
I am doing the paperwork for my RV9A, to make its first flight very soon. Filling in the paperwork I came across the Type designation of my new ECI-Titan engine: "OX-320 A1J1N4-FIS". I tried to find out what all these letters stand for, but was not able to find the "RAETDS" on the WWWEB. (The Fuel injection has been installed by the engine builder, so that is why it is not realy a IOX-320)
Go forums....time starts.... now!
Looking forward to your replies.
Regards, Tonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 05-03-2010, 02:26 PM
phil@aae phil@aae is offline
Tonny,
As per ECi's booklet M262(03/21/07) the "A" Constant Speed. "1" Dynafocal type 1 Crankcase. "J" Bottom-Mount Hot Induction with 2 Non-Impluse Magneto Drive Gears for Electronic Ignition. "1" 8.5:1 Compression. "N" Nickel+Carbide cylinder Bore. "4" Experimental Only cylinder with 14MM Spark Plug Boss.
I would guess the builder added the FIS on the end possibly because they used another Fuel System than ECI'S.
You can also get this information from ECI's webb site www.eci.aero
Hope This helps
Old 05-03-2010, 03:29 PM
Thumbs up I knew it was going to be better than Google!
WOW !!
Most of the times I get 12.500.000 hits on stupid things I don't even want to know, but if I am realy looking for something, it can to be hard to get the right information. I Knew I was going to get an answer "Pronto" through the forums though!
Exactly! Everythig you are saying and a non ECI Fuel injection system installed!
Many thanks, Kind regards, Tonny.
"Pilottonny"
Tonny Tromp
Sold
