  #11
Old 05-03-2010, 10:19 AM
tomcostanza tomcostanza is offline
Hi Scott,
I have Terra/Trimble nav/coms, and audio panel
Garmin GTX320A transponder
TruTrak autopilot
United instruments altimeter and VSI
Narco DGO-10 HSI
Brand X (RC Allen clone) electric attitude indicator
Why did you decide on this equipment?
I bought all of it on ebay, and I thought it was the most bang-for-the-buck.
In a past life I used to service and install communication equipment (C.B. and commercial FM), so I was able to fix most of the electronics that needed it. The stuff I couldn't fix, I made sure I could return if it was defective.
Did you buy new or used equipment?
All used, some refurbished/yellow-tagged.
Who did the install, you or an avionics shop?
I installed/am installing it.
Is this an original installation or an upgrade?
Original
There is a saying that a true sports car doesn't have anything that doesn't make it go faster. You might extend that to stop faster too, but you get the idea. While that isn't entirely true of a sports plane, I think it's pretty close. And it seems to be Van's philosophy. I know from this forum that most will disagree. I'd rather have good-enough avionics and more money in the bank.
All the best,
Tom Costanza
Langhorne PA
Tom Costanza
RV-7A Fuse
Old 05-03-2010, 12:13 PM
My non-RV started out with ancient instruments, literally WW2 vintage. A 360-channel KX170 (nav side was never used), a Bendix T12 ADF and "shout loud" intercom.
I've since updated the panel myself with a Dynon D100 EFIS, Lowrance 2000c GPS, Icom A210 comm, Garmin GTX320 transponder and a SoftComm vox intercom. This is a beautifully integrated VFR panel, and I may yet install the Dynon autopilot servos.
If I were doing it all again today I would install the MGL V10 comm radio (best intercom in the business from what I've experienced), an AvMap EKP-IV GPS (because Lowrance is out of the aviation business) and a GTX327 transponder if money would allow. If I felt really rich I'd throw in a Narco 122 or VAL 429 integrated VOR/ILS receiver/indicator just to get a source of non-GPS nav info.
As for the wiring, I've made my living as an avionics guy so wiring was a no-brainer. Given the really crappy audio I often hear from homebuilts I wish more homebuilders would pay a professional to do their audio wiring. Just my two cents...
Old 05-03-2010, 12:31 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Originally Posted by Scott Spangler View Post
Specifically, what make, model, and year RV do you own, and what make and model communication, navigation, surveillance radios, and/or instruments are in your panel?
Scott-I'm sure you're already aware of this, but it's pretty important that your conclusions of what RV'ers put in their panels is not limited to data derived from us here on VAF. While a lot of RV'ers do follow the forums, those that do are probably biased toward toward newer technology. There are a whole lot of other RVers who don't spend much time on the internet (especially forums) and they are much likely to have the standard 6 pack type of instruments.
Regardless, good luck with your study. I'll look forward to reading the results.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 05-03-2010, 02:59 PM
Jamie Aust's Avatar
Jamie Aust Jamie Aust is offline
Way back in Jan 09 my panel looked like this.
I had not even start to build the fuse yet.
Now in march 2010
So thats one upgrade for me, and I have not finished it yet.
Im installing it all myself as thats my trade. ( electronics tech ).
Eq list.
2 x 10" dynon skyview Efis, garmin 327 transponder, Icom A200 ( used ), SPA-400 intercom.
I cut out the panel myself with just hand tools.
I would say, if you are building a slow build like myself, dont get radios, instruments etc until you have the fuse ready for the panel to be installed. Another point is that if you dont live in the USA, you had better find out what basic instruments are needed for your area, or you may find you need extra holes in the panel.
well thats my 2c
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
Old 05-03-2010, 05:15 PM
flyvans.com flyvans.com is offline
general comments
generally, i agree with what everybody chimes in on trying to do avionics last and waiting for the last possible moment. there's so much new stuff coming out and ever more features for the same price available.
HOWEVER, do not wait with planning and closely monitor the market from the beginning. at one point decide on a "design freeze" and stick to what you have, even if there's new developments in the meantime. also, expect high levels of frustration when trying to plan ahead only based on documentation/paper/theory. some documentation in the avionics sector is marginal at best and lots of things can only be reliably planned once you have at least the cradles and/or connectors in hand.
there are other hurdles, e.g. the damned high density d-sub connector on the garmin transponder requiring special tools and very expensive pins, while everybody else seems to have settled on regular d-sub. same goes for a few types of antenna connectors.
and even with careful planning and considering all installation manuals and best practices, there will be lots to troubleshoot, audio noise is such an example or differing wiring styles of serial grounds. also, rs-232 is not necessarily rs-232 by the specs... problems with signal level drops and such...
regarding the physical planning, a 3d solid cad model certainly helps. however, the substructure can be a pain to integrate.
for the actual cutting of the panel, IMHO there is no way around cad / laser or waterjet cutting. the final result justifies the extra expense.
model, year
RV-7A, expected first flight very soon (only paperwork remaining)
panel
our panel is about as stuffed as one can get it ;-)
sources, new?
bought all the stuff from various sources on the internet, some steinair, some pacific coast, some from advanced and vertical power directly.
all new.
installer
installed all of it on our own, with the exception of some rough pre-made harnesses.
original or upgrade
original installation.
equipment and reasons
Advanced Flight Systems AF3400EF and AF3400EM synthethic vision models.
great track record of the company, innovative products, nice graphics resembling the airliner type EFIS symbology, highest level of integration (besides GRT and the more expensive garmin stuff) in the market (flight director etc...). although dynon is now catching up in leaps, this was not the case at time of planning. high quality AHRS. form factor enabling enough space for all the screens. flexibility of the owner to cooperate with the AFCU "pet project". documentation is about average, some of it is excellent (installation of probes e.g.), some areas could be better and reflect software changes more closely.
Advanced Flight Systems AOA
no stall warning per default on the RV. the reason we didn't get it integrated with the efis (as is now available) is a good example for not to buy avionics too early. we had purchased it when doing the wings for the probe install.
don't mind the separate indication / system independence however
Garmin GMA340 Audio Panel
GMA240 would fit the mission just as well and cheaper, but again, that wasn't out yet when we started planning. also, one of the avionics that we purchased early on (maybe a bit too early).
Garmin SL-30
the logical choice when one decides not to use a gns430. (cheaper, didn't require a certified gps, tight on space)
serial interface makes wiring relatively easy, because the cdi also operates through the serial. also uses standard d-sub connectors which are easy to wire. great features all in one unit.
Garmin GTX-328 Transponder
mode-s requirement in europe. pretty much standard, little competition in the market, only from lesser known companies that unfortunately have either price or performance problems. pain in the *** high density d-sub connector. also, documentation is poor and there are undocumented incompatibilities with gps data formats (no nmea apparently!)
ICOM IC-A200
simply wanted a full and simple com2 panel mount
good bang for the buck while blending into the stack.
wiring somewhat tricky, different connectors, documentation minimal.
Vertical Power VP200 electrical system
a bit of a risk as we are early adopters. basically convinced us in person/demo at their first oshkosh appearance. completely new way to do the electrical system. have only praises so far. works like a charm with awesome features and greatly adding to the "airliner" feel. at the same time it made wiring/installation simpler. no competition yet in this segment.
excellent documentation from A to Z.
Trutrak Flight Systems Autopilot AFS Pilot.
the only autopilot compatible with a high level of integration (vertical commands from flight director) at time of planning.
ezpilot did not have the vertical features and dynon only just launched their autopilot (with teething troubles that were to be expected).
AFCU and MapPC "pet projects"
These two units cannot be purchased off the shelf and are our own side-projects. The MapPC is essentially an embedded pc with a display and interface unit. This base allows us to experiment and advance our navigation system into the future all the while being fully integrated with the EFIS and therefore autopilot.
The AFCU is simply a remote control unit for the efis to simplify mode selection and make up for the lack of discrete rotary knobs for each function.
good luck on your study!
bernie
Buelach, Switzerland
Bernie Daenzer, Alex Lichtensteiger
www.flyvans.com
RV-7A
S/N 72072, Flying!
HB-YMT (Switzerland)
Old 05-03-2010, 06:17 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
My six pack panel came with the plane along with a Garmin GNS430 and Rocky Mountain engine monitor. I upgraded to a 430W and added a Trio EZ Pilot and Altitude hold.
While new RV aircraft are probably close to 100% glass, I have been all over the country, to the Bahamas, Caymans and Mexico with what some would consider outdated instruments.
Old 05-05-2010, 09:11 AM
Scott Spangler Scott Spangler is offline
Originally Posted by RV7Ron View Post
Not to answer for Mike, but you wait because the state of Avionics is constantly in flux these days. If you decide on your avionics two years in advance...you will already be behind the curve when you finish your plane. New technologies and capabilities are coming out all the time and competition is really driving prices down....or at least increasing the bang for your buck. With some of the E-AB targeted (not-TSO) Avionics out there now, the competition has been great for us consumers. I am already resigned to the fact that I will wait til the last minute, buy my avionics, and know that a few years after its flying it will probably be out-dated again! Its a revolutionary time for Avionics development right now.
Excellent points! Thanks!
Old 05-05-2010, 09:23 AM
Yup, I'm aware, and the good folks here at VAF are just one of several sources I'm using for the story. I'm also working several homebuilt, vintage, and warbird online groups, custom panel builders, and several decades worth of cockpit explorations at Oshkosh.
