Old 05-02-2010, 07:28 PM
odens_14 odens_14 is offline
Default Mags always grounded?
I was wiring my mags today on a brand new IO 360 M1b engine from vans. Well when I finished both mags were always grounded, I figured the shield must be touching the center conductor, but when I checked with the voltmeter the wire is good. Now this has me really confused, with all the wires disconected from both mags they are both still grounded??? I tested this by using my voltmeter from the p-lead to the firewall. can someone please tell me what I'm missing, I can't have 2 bad mags on a brand new engine can I?
Chris Odens
Alexandria, MN
RV-7 N914N
FLYING!!! as of 7/22/10
Build Log
Old 05-02-2010, 07:37 PM
Mel's Avatar
Mel Mel is offline
The mags are grounding through the points. If you turn the prop, you will find a point where they are ungrounded when the points open, but this is not a safe practice with the spark plugs in the circuit as the mag will fire.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 05-02-2010, 07:43 PM
*sigh of relief*
Thanks, Mel, I was hoping it would be something simple like that. I'll pull the leads off and turn the prop a bit.
Chris Odens
Alexandria, MN
RV-7 N914N
Build Log
Old 05-02-2010, 07:47 PM
Bob Kuykendall's Avatar
Bob Kuykendall Bob Kuykendall is offline
Originally Posted by odens_14 View Post
...can someone please tell me what I'm missing...?
I think that just about every conductor inside the magneto is connected to ground either directly or through either the primary or secondary coil. I think that if you check closely you'll find at least some resistance on the P-lead terminal, that being the resistance of the wire through the coils.
Here's an article with a typical magneto schematic.
As I recall, the P-lead grounds the end of the primary coil that goes to the condenser and to the points. So you'll find near zero resistance at the P-lead terminal when the points are closed, and a bit more resistance when the points are open.
Thanks, Bob K.
Old 05-02-2010, 07:58 PM
aerhed aerhed is offline
Also, There's probably a spring steel tab your P-lead cigarette screws in against. If the P-lead is unscrewed this springs against the case & grounds.
Old 05-03-2010, 12:21 AM
az_gila's Avatar
az_gila az_gila is offline
Question Only on Bendix...
...mags, not Slick ones, correct?
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 05-06-2010, 09:46 AM
Tom McCutcheon Tom McCutcheon is offline
Also, if you are trying to check with the key in the off position all the mags are grounded.
Old 05-06-2010, 09:51 AM
Gil, right-o. Bendix does that.
