Originally Posted by Geico266
A little wire brush and that prosealed cleco will be good as new...
Originally Posted by lorne green
Na, Rick dipped it in Boelube before using....
I suppose you
*could* use a wire brush or boelube to clean or prevent proseal from sticking to a cleco button but why bother? I use nothing, nothing at all. Any proseal residue that clings to the button is mostly a cosmetic issue for the builder. Unless the same cleco button is used with wet proseal over and over again (a highly unlikely scenario for the amateur homebuilder) in that case the cleco will eventually develop several layers of cured proseal and over time it is that build-up that may interfere with normal operation. Even so, for a well-appointed production shop using lots of proseal on a daily basis that is no big deal because the clecos are simply immersed in industrial strength ultrasonic machines to strip and clean them to restore performance. After all, production shops can't be paying people to sit around and clean proseal off cleco buttons, nor is it economical to toss the clecoes out either. Unless mechanically damaged,
it is not proseal but the cleco button's spring or shaft that tend to wear out that will render the cleco button unusable.
The simple act of removing the cleco buttons from the holes shown in the photo below will strip most of the proseal from the cleco buttons. If the builder decides to take the time to further clean the clecos, he's got more time to waste than I do.
