Charlie,
Servicing the brake fluid reservoir is going to be your biggest issue with putting it aft of the firewall. Also, I believe you want it as high as possible so any air bubbles move up to the reservoir.
Besides, I would much rather clean the engine side of the firewall than the footwell.
If you are worried about spilling brake fluid, why not plumb in a second reservoir to catch what comes out of the top of main one? Either that or don't fill the main one to the top. (I suspect it will sill leak though.)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
