Old 05-01-2010, 01:19 PM
dtaylor dtaylor is offline
Default Amperage Droppoff Problem
I am having an intermittent problem with my amperage dropping off to zero and then into the negative 30 and then negative 40 amps. This lasts for 1-2 minutes and then then the system restores to normal. I can also fix the problem by switching the alternator off and back on. My voltage reads 14.2 the whole time indicating that my alternator is still working ok.
I have a B&C LR3C-14 voltage regulator and a bone-simple single alternator conventional engine setup.
Has anybody had one of these units go bad like this?
Thanks for the advice!
Dave T.
Old 05-01-2010, 02:21 PM
Brantel's Avatar
Brantel Brantel is offline
Where is your current shunt or hall effect sensor located???
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 05-01-2010, 03:20 PM
pauldan181 pauldan181 is offline
Is this a Van's ammeter? I'm on my third one and each one failed as you describe, occasionally going full 40 neg. then finally always full neg. as long as the battery was on. It would still be a good idea to check all your connections but I haven't had good luck with some of Van's gauges.
Paul Danclovic
Jamestown NC
RV-8A N181SB
Old 05-01-2010, 04:47 PM
Dave T.
How is the ammeter hooked up?
If it is on the battery lead, you are reading load going into and out of the battery. Normally, it will read a load while the battery is recharging after a start and then read zero when the battery is full. It could be you have the leads on the ammeter reversed. Try reversing the leads and see what it reads.
I have mine hooked up in series with the lead from the alternator. It ALWAYS reads a positive load. That load drops off as the battery is recharged.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
