Go Back   VAF Forums > RV Firewall Forward Section > Fuel Injection Systems
  #11
Old 05-03-2010, 06:16 AM
Don at Airflow Don at Airflow is offline
Default Pump check
Just send the pump back to us with a note explaining what's going on. If we can not fix it we will have to replace the pump.
Don
Old 05-03-2010, 09:42 AM
odens_14 odens_14 is offline
Thanks Don, I'll send it out today.
Chris Odens
Alexandria, MN
RV-7 N914N
FLYING!!! as of 7/22/10
Build Log
Old 05-04-2010, 09:35 AM
JDanno JDanno is offline
Slightly off the subject......are the Airflow pumps okay to run auto gas with a small amount of alcohol in it?
Also what is the fuel pressure out of the pump?
Old 05-12-2010, 10:23 AM
Update: Figure out I have a problem with my fuel pump on a friday night and post here, have a response from the head hancho the next day (a saturday). ship it to them and today I recieved my pump back from airflow in working condition at no cost to me. This is what I love about the companies that support our hobby, A+ customer service!
As far as the cause of the failure it was appearently from running dry, which I believe happend because the preservative oil must have drained when it was sitting in the fueselage for over 6 monts bbefore I ran it for about 10 seconds, my advice to others would be to make sure you have fuel in the system before even testing the pump, even very briefly.
A special thanks to Don at Airflow for his help!
Chris Odens
Alexandria, MN
RV-7 N914N
Build Log
Old 05-12-2010, 10:37 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Chris, thanks for closing the loop with this.
I have to add my own kudos for Don, great customer service was my experience also.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
