Old 04-30-2010, 09:53 AM
danielhv's Avatar
danielhv danielhv is offline
Default Spray Bottles...
So Ive been using the trigger spray bottles from home depot or lowes for quite some time now... i go through them fairly quickly because the MEK i guess eats up some stuff in the bottle and it starts leaking from under the trigger... I cant seem to find a spray bottle that will stand up to it. These from HD and lowes only last a few weeks max. Any suggestions?
Old 04-30-2010, 09:57 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Harbor Freight sells a unit you fill, then pump up with an air hose-----makes it into something like a spray paint can.
Dont know if the innards will stand up to MEK???
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-30-2010, 10:13 AM
danielhv's Avatar
i use it for spraying MEK to wipe down for priming or for proseal cleanup... I looked at Grainger and they have "chemical resistant" trigger sprayers, but it doesnt say what chemicals it will resist...
Old 04-30-2010, 11:03 AM
Andrew M's Avatar
Andrew M Andrew M is offline
Default Check this out
I use these as work, cuts down on arosol/ vapor as well. last forever.
http://www.usplastic.com/catalog/def...arentcatid=469
Andrew
