Old 04-29-2010, 11:17 PM
tx_jayhawk tx_jayhawk is offline
Default Hose Clamp Over Firesleeve?
Is it acceptable to use a regular stainless hoseclamp over firesleeve? It is for a short section of rigid fuel line between two devices on the firewall (flex line is connected to the engine). I wanted to slip some firesleeve over it, but don't konw whether a "real" clamp is needed.
Scott
7A
Old 04-30-2010, 03:05 AM
shuttle's Avatar
shuttle shuttle is offline
Default Safety Locking Wire?
Scott,
If you are just looking to secure the firesleeve then how about a twist of Safety Locking Wire at each end.
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
Old 04-30-2010, 05:36 AM
Randy Hooper Randy Hooper is offline
Default Stainless Steel TyWrap
HomeDepot/Lowes has a stainless steel tywrap that looks nice on firesleeve.
Randy Hooper
RV-8
N84H
Old 04-30-2010, 08:52 AM
lrfrey lrfrey is offline
Hose clamps are quite acceptable, as is safety wire. I used a double wrap (twice around before twisting) to secure mine. EAA has a video on it if I recall correctly.
Larry
