Originally Posted by RetiredRacer
I have a question or two for anyone who has installed Aeroleds.
Aeroleds have a RV nav/strobe kit listed. this kit uses the 10 watt "Pulsar" NB90's in the wing tips, and the 20 watt "Suntail" in the tail. My question is, is there any reason why you can't use the 20 watt "Pulsar" NBT's in the wingtips?
You can, but it won't buy you anything. You still will be required to have a position light on the tail. At least here in the US. There is no need to have 180 degree lighting, since the wingtip will block any light towards the read. That's why AeroLEDs came out with the NS90 package just for RVs and other similarly configured aircraft.
My second question is (as I'm about ready to close up the wings and want to pull the wiring), what gauge wire would be required for these units?
I have sent Aeroleds a email with these questions, but they have not got back to me.
You have a 3A load on the strobes. 20 guage is fine up to 5A.
Also, order the NS90s from Vans. They're less expensive there.
bob
