BE VERY CAREFUL!
Originally Posted by Inverted
I am looking at an engine that has a solid crankshaft. It is my understanding that I will need a hollow crankshaft for a CS prop. How expensive(ballpark) will it be to replace the crankshaft when rebuilding the engine? Is it possible to have the solid one modified?
Just because an engine has a hollow crank doesn't mean it will accept a C/S prop. There are several other considerations. Like, does it have a governor pad? Does it have the proper front main bearing configuration?
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
