Old 04-28-2010, 11:25 AM
apkp777's Avatar
apkp777 apkp777 is offline
Default Priming 2 Cylinders only
Hey all,
I am installing my engine fuel primer. I initially was thinking of going with a 4 cylinder set-up, but after running the lines, I am thinking I don't like the looks of it and was considering going with just a 2 cylinder prime (#2 & #4).
Anyone have any input?
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 04-28-2010, 11:36 AM
videobobk's Avatar
videobobk videobobk is offline
Not a bad idea at all. Some production aircraft use three cylinder priming so that it isn't likely to flood all cylinders. Two should work just as well, IMHO. I find I only need priming when it is below 30*F anyway, and at those temps I usually preheat. A couple of stroke on the throttle will start about anything with a good battery in most conditions.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 04-28-2010, 11:41 AM
apkp777's Avatar
I am thinking that priming 2 cylinders would be just as effective as 3 or 4. Combine that with preheating in the cold months.
Van's Primer Kit comes for a 2 cylinder setup, they must feel 2 cylinders is sufficient.
Just thinking out loud.
Tony Phillips
Old 04-28-2010, 12:01 PM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
I only ran primer lines to 2 and 4, much easier to plumb. Starts just fine in the cold WI wx.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 04-28-2010, 12:05 PM
apkp777's Avatar
Thanks Jeff, great meeting last night. Kind of makes you want to think about flying gyros, or eating gyros, not sure which I'd like better.
Tony Phillips
Old 04-28-2010, 12:14 PM
vic syracuse vic syracuse is offline
Super Moderator
I only primed one cylinder on my 7, and it has worked fine through 2 winters, albeit Atlanta winters. Some starts were in the upper 20's after being cold soaked all day.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 04-28-2010, 03:58 PM
jsharkey's Avatar
jsharkey jsharkey is offline
I primed the two forward cylinders. Worked great so far over a cold NE winter.
Jim Sharkey
RV-6
Old 05-19-2010, 02:13 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
So, assuming one is going to prime two cylinder's only, can which two you chose be based simply on where the routing is easiest? For example, is priming #1 and #3 (both on the right) just as appropriate as priming #3 and #4 (one on left and one on right)?
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 05-19-2010, 02:55 PM
apkp777's Avatar
I am planing on priming 1 & 3 for easy routing. It makes no difference which 2.
Tony Phillips
Old 05-19-2010, 06:29 PM
Steve Steve is offline
I'm with Bob K with no priming system at all. And it gets cold and snowy during those winters in northern Utah. A touch of pre-heat and 2 pumps on the throttle then crank it over. Starts on the 2nd blade every time. My RV6 bud's primer line broke just after the pump (forgot the service loop). He pinched off the tube and ran without the primer for a couple of months and never noticed anything different during engine start.
You'll also be flying sooner.
Five Sierra Fox
RV-9A
Utah
