FAB Flapper Hinge Pin & Cable
In constructing my FAB, I didn't see anything about safety wiring the hinge pin for the flapper door. It seems to be captured in the assembly but it also looks like it could eventually viberate laterally & wear into the aluminum.
Did I miss something or is this a non-issue?
Also...Does the Van's-supplied cable (A-720?) perform ok over the long run?
Do the ratchet detents prevent it from backing out, causing addition of carb heat? Thinking of an upgrade here...
Thanks.
Sam Evans
RV7-A O-360 C/S
VAF#812
