Front and Rear assemblies?
The only suggestion is to make sure you have the front and rear assemblies in the right place. I switched them somehow and got similar results to yours. There are dimensions on the plans of mine showing the length and to cut if/as required. I didn't have to cut mine and after getting them in the right place it worked perfect.
Good Luck
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
