Old 04-24-2010, 10:22 AM
rv4ator rv4ator is offline
Default Voltage Regulator Wiring?
I am replacing an external voltage regulator that has three wires to connect. A red wire is connected to a split master switch, green to "field" & black to ground.
The replacement regulator (Transpo M5-130) has four wires. Their spec sheet lists them as follows: Red to isolation diode(+), Black to ground, Green to field & Yellow to ignition.
Does anyone know if the Red wire needs to be connected? Where?
