I didn't like how the aluminum angle joggles from Vans were deformed (both for the firewall and the forward floor stiffeners):
So I made up some tooling at work:
That clamps around piece of aluminum angle:
The two blocks on each end are solidly bolted in place, but the middle block is guided in slots on the side plates so that a hydraulic press can be used to push it down:
Resulting in a nice, even joggle:
The new joggles need a little filing and polishing to clean them up:
The joggles ended up being much better behaved and it was easy to control the "depth" of the joggle (.125 in this case). Notice how the new angle (bottom) doesn't have the "hump" that the original (top) did:
I cut the newly joggled angles to length, transferred the holes from the previous angles, and countersunk. They fit quite well:
BTW, anyone is welcome to borrow the joggle tooling for the cost of shipping both directions.
Good luck.
