Old 04-21-2010, 08:40 AM
odlee odlee is offline
Default Gretz pitot problems
My 2 yr old Gretz has begun to delaminate. I have sent an email with photos to the new manufacturers ( Angus Aviation), but have received no response. Can the polymer surface be repaired? Will a high temp epoxy or JB Weld hold?Pitot heat still works. About 150 hrs total on the plane.
David
[IMG][/IMG]
[IMG][/IMG]
Old 12-12-2010, 10:23 PM
MikeJ 7A's Avatar
MikeJ 7A MikeJ 7A is offline
Just wondering how this issue was resolved?
RV-7A, VAF# 837, Working on the Wings
"Measure Twice, Cut Once"
Old 12-13-2010, 12:12 PM
Default Replaced by SteinAir.
I discussed this with the current manufacturer, now in Australia. It seems this has happened on other units. Be sure you follow the wiring instructions. The unit does not stay in a continuos heating mode, but cycles. If wired incorrectly you will overheat the unit and caused a problem similar to those shown in the photos.
Mine was wired correctly and seldom used. New unit is OK.
Good luck,
David
Old 12-13-2010, 01:47 PM
MikeJ 7A's Avatar
The "powered only when needed" idea seems great at first glance, but I wonder what failure modes are introduced with this?
Perhaps a failed sensor caused the unit to be on continuously. Worse cast senario, sensor fails to indicate need for pitot heat and it ices over?
