Check the web site of Aeroinstock.com They advertise on this site. If you cannot find it on their web site, PHONE them or one of the other Engine builders that advertise here.
If you lived closer, I have some Lycoming studs in my hangar and you could pick through what I have to see if I had the ones you need.
Yes a hardware store stud MAY work on an EXPERIMENTAL but it is possible that it could be manufactured on the opposite side of the tolerance you need for the hole in your expensive aircraft part.
Gary A. Sobek
NC25 RV-6 Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
