Old 04-20-2010, 07:28 PM
rv7charlie rv7charlie is offline
Default avionics challenge
OK, who's going to be the 1st to tie one of these to an AHRS/single board pc running EFIS software & point it at the windscreen?
http://www.geeks.com/details.asp?Inv...-MiniAVLEDMain
Charlie
Old 04-20-2010, 08:28 PM
Norman CYYJ Norman CYYJ is offline
Should make a great HUD or project a picture for GIB.
Old 04-21-2010, 08:37 AM
John Courte John Courte is offline
You'll need some custom optics and software. The FOV of that projector is goo narrow for a panel/subpanel mount, the focal distance is too far out, and if you place it overhead, you'll see the glare from the lamp. But you could probably cobble up a camcorder fisheye lens to compensate for the FOV, and maybe that would fix the focal as well. All you need then is an Open GL 2 shader that distorts the image to be the inverse of the curvature of your canopy.
Just don't move your head around too much.
Personally, I'm waiting for the big leaps in augmented reality tech to go mainstream, like glasses that display information superimposed on your normal view, or a few years down the road, project it directly on your retina with microlasers or lensed LED's.
RV-7 N313TD
SOLD 7/2/2020
