Old 04-19-2010, 08:50 AM
Doug94 Doug94 is offline
Default Heated Dynon Controller installation
Pretty specific here, but does anyone have a recommendation on where and how to mount the control unit for the dynon heated pitot? A picture of what you did would be worth a million words. Thanks
Old 04-19-2010, 12:15 PM
roee roee is offline
Default Here ya go
Photo:
Writeup:
http://www.kalinskyconsulting.com/rv...703_ctrlboxmnt
Roee Kalinsky
San Diego, CA, U.S.A.
RV-7A under construction
www.kalinskyconsulting.com/rvproj/
Old 04-19-2010, 01:12 PM
Camillo Camillo is offline
I made also the same. I fabricated two spacers to separate the unit from the bulging part of the spar. Then I placed two platenuts behind, in order to be able to change the unit with minor efforts, should it break after wing riveting.
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 04-19-2010, 01:28 PM
Default heated pitot
Thanks guys! You all are the best resource around
Old 04-19-2010, 02:37 PM
jchang10 jchang10 is offline
I just mounted mine to the far outside wing rib. Far easiest for access.
#40533 RV-10 Builder and CFI
1/2006 Started build
10/19/2011 First flight
Old 04-19-2010, 07:39 PM
guccidude1 guccidude1 is offline
I have a QB -9A and the wings were already closed. Sorry, I don't have a picture, but I can describe it fairly well. I mounted my controller on the inspection plate next to the pitot. It was easy to install and is now very easy to inspect. I just looked at it yesterday for my third annual condition inspection. Dan
