Old 04-19-2010, 12:59 AM
Akutan Bandit Akutan Bandit is offline
Default Cylinder Question
I'm digging around for a cylinder for my O-235 C2C and am having trouble identifying the correct application.
I've found a yellow tagged cylinder for sale that appears to be the correct part number, an LW-16704. However this has an -lr designation after which appears to mean its an angle valve cylinder. Am I correct in assuming that this is incompatible with my parallel valve engine? The application charts I've found from lycoming leave the suffix off the cylinder designations when grouping by engine type and mostly just group by compression. I don't know enough about engines to be shopping intelligently for this part.
Thanks for any help.
Old 04-19-2010, 01:57 AM
RetiredRacer RetiredRacer is offline
Default 0-235 Cylinders
I've just ordered new cylinders for our 0-235 C2C. (Narrow Deck-Short Reach Plug-Low Compression)
Air Power Cylinders list it as Lycoming part # 05K23039.
