04-18-2010, 04:38 PM
What rivet type is this? (OIDC)
I noticed after doing inventory on my fuselage kit that I have rivets with two different markings in my AN426AD4-6 rivet bin. One type of rivet has a dimple in the middle and a single mark outside the dimple that looks like a cross between and an 'F' and a '#'. The other type rivet has a dimple in the middle and the letters 'OIDC' around the dimple.
Are these both AN426AD4-6 rivets? Or did I miss something in my inventory?
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
04-18-2010, 05:37 PM
I would bet that....
I would bet that they are both 426AD rivets with different manufacturers.
The manufacturers are now required to have unique registered identifying markings on solid aluminum rivets larger than 3/32 nominal dia. They may be required on other materials to, but I have not verified it.
04-18-2010, 07:26 PM
Sounds like yours all do, but make sure they all have a dimple in them. I received some OIDC AN426AD4-5's with no dimple and they were very soft. Van's confirmed the mistake and issued a notice to others.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
04-18-2010, 09:24 PM
Originally Posted by boom3
...I received some OIDC AN426AD4-5's with no dimple and they were very soft...
Minor nitpick: Actually, those would be AN426A rivets, not AN426ADs. ADs (dimpled) are 2117 alloy, As (no marking) are 1100, and Ds (raised dots) are 2017.
Thanks, Bob K.
04-18-2012, 06:33 PM
use for A rivets?
I just rec'd my latest order from 'spruce; unfortunately didn't realize that I ordered a few sizes of A rivets instead of AD. Didn't discover 'till after I dumped the new rivets into the old bins... have some sorting to do! Is there any common use for the A rivets? Or should I trash these as a means to prevent using an A rivet where I wouldn't want one?? Fortunately, it's only a few sizes, 1/4lb each so no great loss.
04-18-2012, 06:49 PM
A Rivets
Trash the A rivets. Cannot be used for structure.
Personally, I would toss all of them that are mixed up. Rivets are cheap.
04-18-2012, 07:02 PM
HTML Code:
Rivets are cheap.
unless you need only three rivets but need to buy a 1/4 pound of them. Then they're $5.00 each
Needed three AN426AD5-6 rivets to attach the ring around my Garmin GMU44. Anyone else need a few? I have spares!!!!
Carl - - Morrison, CO
N16CB RV7A
Airworthiness cert issued 12/24
best X-mas present I could have hoped for!
paid 'til 10-19
04-19-2012, 04:54 AM
Originally Posted by ColoCardinal
HTML Code:
Rivets are cheap.
Just a tip, at your next spruce order, buy a minumum amount of long (like -16) rivets. You can always cut them down to the length you need. This way you never have to worry about be short a rivet or two and having to order a whole bag and wait for delivery.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
04-19-2012, 09:14 AM
HTML Code:
Rivets are cheap.
Spruce let's you order 0.13 of a pound. $2.20 total for the rivets you mention...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
