Nope
Nah, it's not hard at all. Here's another trick I learned from Gary Sobek which works great...
When you first install the airseal, it will tend to stick up straight. You want it to curl over into the plenum like Roberta said. So what you can do is this...
In the corners, take a piece of masking tape and tape the corners together so that it holds the baffles bent into the plenum chamber. This keeps the airseal bent over in the right direction those first few times you put the cowl on.
After you run the engine and fly once or twice, the baffles will conform nicely, and you can take the masking tape off if it's not off (blown off, worn off, whatever) already.
The masking tape doesn't hurt a thing, and it's a good alternative to lacing or using tie wraps or safety wire or rivets or... I've seen a lot of cases where builders use something like that to "bind" the corners together, and in my opinion it's not necessary. Anything you use to bind the corners could wear against the top cowl. No need for that. Use masking tape and it'll work out great!
)_( Dan
