Old 04-16-2010, 11:57 PM
PIN 37 PIN 37 is offline
Default Power cable through firewall, how?
Is there anybody out there that can tell me how to get the main power through the firewall into the cabin. Do people simply put a cable through a hole in the firewall using a rubber grommet? or is there some tricky device available that can be fitted to the firewall that allows power access both sides, cabin and engine side? Any help or advice would be appreciated.
Old 04-17-2010, 05:28 AM
jsharkey's Avatar
jsharkey jsharkey is offline
Default Snap Bushing and RTV or Firewall Sealant
Van's FWF drawings call for snap bushings gooped up with high temp/fire proof sealant. There are other methods including rubber grommets with stainless fire covers, "eyeball" swivel penetrations etc. The Van's method is light, cheap, simple and effective.
Jim Sharkey
RV-6 Phase 1 almost finished
Old 04-17-2010, 05:39 AM
pierre smith's Avatar
Default Hi Philip....
...Bob Knuchols (sp?) is the go-to guy for all your electrical/wiring advice and solutions. Here is the page entitled "Keeping the wiring in and the fire out" or something like that:
http://www.aeroelectric.com/articles.../firewall.html
He has probably the best publication on safely wiring your entire airplane as well,
Best,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-17-2010, 09:14 AM
Rupester Rupester is offline
Default I just went thru that decision process ...
I decided on a rubber grommet covered by a "clamshell" SS cover.
The Nuckolls method using fireproof jacketing looks great ... problem being the difficulty of finding 1" diameter SS flange to rivet/bolt to the f'wall. The only ones I could find are aluminum.
Terry Ruprecht
RV-9A Tip-up; IO-320 D2A
S. James cowl/plenum
(Dues paid thru Nov '18)
Old 04-17-2010, 09:27 AM
Tom Martin Tom Martin is offline
For big wires I like to use one of the firewall penetrations offered by http://www.planeinnovations.com/ If large current wires ever short out there are going to be a lot of sparks. Plastic bushings on a stainless steel firewall, even covered with goop, are a long term accident waiting to happen.
Tom Martin RV1 pilot 4.6hours!
CPL & IFR rated
EVO F1 Rocket 1000 hours,
2010 SARL Rocket 100 race, average speed of 238.6 knots/274.6mph
RV4, RV7, RV10, two HRIIs and five F1 Rockets
RV14 Tail dragger
Fairlea Field
St.Thomas, Ontario Canada, CYQS
fairleafield@gmail.com
Old 04-17-2010, 09:32 AM
ccrawford ccrawford is offline
Post One option
I was looking at this last night too. Found this:
http://www.aircraftspruce.com/catalo...enetration.php
Looks like the Plane Innovation version of this is a bit cheaper.
However, I will probably go the rubber grommet + stainless cover route.
// corey crawford
// rv-7a (sold)
// denver, co @ KBJC
Last edited by ccrawford : 04-17-2010 at 11:08 AM. Reason: modified to remove incorrect info (asc kit *is* stainless)
Old 04-17-2010, 12:12 PM
beav's Avatar
beav beav is offline
Default Another Choice
SafeAir1 makes a 1" version as well that's even cheaper than the Plane Innovations one and includes stainless steel mounting hardware. You can buy them through Avery:
http://www.averytools.com/pc-1003-12...-thru-kit.aspx
jason
N4VR
RV-7 (Flying)
http://www.jasonbeaver.com/rv7
Old 04-17-2010, 08:09 PM
panhandler1956's Avatar
Default Here's what I did
Lowes $22 for a ss handhold in the plumping section. Cut off the ends and you have two.
http://www.lowes.com/pd_116778-22910...20bar$y=9$x=11
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 04-17-2010, 09:33 PM
sf3543 sf3543 is offline
Default Look at this
I have used these with great success. It allows you to isolate the positive lead through the firewall
http://www.speedwaymotors.com/BATTER...CTOR,2353.html
It requires a hole about the same size as an eyeball pass through.
You can't beat the price.
I have also made some smaller ones of my own using some uhmw block and threaded brass rod that have worked well.
Good luck.
Steve Formhals
A&P, Tech Counselor & Flight Advisor
RV3B
RV8
Old 04-18-2010, 04:04 AM
Good luck.
Steve,
I like your solution better except I worry about the plastic melting in case of a fire, etc....maybe I'm too paranoid about that from reading all the Dan Horton posts about firewall insulation. Your installation is definitely elegant and certainly another option I considered.
Regards,
Brent Owens
Columbus, OH
N784DE S/N #82614
