Old 04-16-2010, 07:35 AM
Fearless's Avatar
Fearless Fearless is offline
Default #4 screw one-leg nutplate?
Does anybody have any MS21071-L04 nutplates they could part with? I know Genuine Aircraft Hardware sells them but I only need 4 and you have to buy a pkg of 25 from them.
If I don't get any response I will just end up using #6 screws instead where I won't have any problems getting one leg nutplates.
Mike
RV-9A Based K6I2
Flying - out of Phase 1
Building RV-12 with brother
Old 04-16-2010, 07:48 AM
prkaye prkaye is offline
I think I posted this exact question a few months back, but I can't seem to find the thread. Aircraft spruce has one-lug floating anchor nuts for #4 thread...
http://www.aircraftspruce.com/catalo...anchornuts.php
and this works fine. Another suggestion was just to cut one lug off a regular nutplate - given the relatively low torque of #4 screws one rivet should hold it fine while you put the screw in.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-16-2010, 09:38 AM
aerhed aerhed is offline
In a pinch you can also take a little chunk of like .125 Al & tap it. Then you can cut out a litttle plate any shape you want. Slow, but it can put threads in an odd spot.
Old 04-16-2010, 09:39 AM
Fearless's Avatar
Default ACS doesn't carry one lug in #4
Thanks Phillip but ACS doesn't carry the one lug in #4. I checked both ACS and Wicks before I posted. Cleveland Tools has the two lug model which is where I got the wingtip kit from originally. Looks like ACS only carrys the minature two lug not the MS21047-L04 one. Genuine Aircraft Hardware is the only place I found that has the one lug style in #4.
Mike
RV-9A Based K6I2
Old 04-16-2010, 09:41 AM
Read my reply again. ACS does carry the one lug FLOATING type with 4-40 thread (F2000 MS21061), and this works just fine. You have to scroll down on the ACS page I linked to to see the floating ones.
Phil
RV9A (SB)
Ottawa, Canada
Old 04-16-2010, 09:44 AM
Fearless's Avatar
Default Didn't think of that
Aerhed,
Didn't think of fabricating something on my own. I think I might have some scrap .125 that I may be able to work up something with. Good suggestion.
Mike
RV-9A Based K6I2
Old 04-16-2010, 09:50 AM
Fearless's Avatar
Default Sorry Phillip - you were right
Sorry Phillip - you were right - I didn't scroll down far enough and see the floating ones. I have to order some locknuts from ACS so I'll just add those to the order. I missed those when I was looking in the catalog last night as well. Next time I'll try to open my eyes wider.
Thanks guys
Mike
RV-9A Based K6I2
Old 04-16-2010, 09:53 AM
it's easy to miss stuff on the ACS site... what you see really depends on what you type in the search box, and they haven't done a good job of making sure their site cross-indexes equivalent terms. For e.g., to see all their nutplates, you have to type in the term "anchor nuts" in the box. For a while i never knew they had knife splices, because you only find them if you type in "knife disconnects".
Phil
RV9A (SB)
Ottawa, Canada
Old 04-16-2010, 06:34 PM
Isaac's Avatar
Isaac Isaac is offline
Default #4 one lug nutplate source
Bon Aero is another source for "MS21061-L04" #4 floating one lug nutplates.
http://www.bonaero.com
From the inventory link, click on nuts and scroll down. You will find them. They don't have fancy on-line ordering but I have placed phone orders with them and gotten good service.
There must be a reason why they are not available, but I have never found a supplier of the standard one-lug MS21051 #4 nut plate
___________
James
RV6 N947J
