Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 04-13-2010, 05:31 AM
flickroll's Avatar
flickroll flickroll is offline
Default Air Gizmo Garmin 696 XM Connector
The G696 uses a mini USB connector to attach the XM antenna to the unit. Because of adjacent connectors (power, remote GPS antenna, audio) the XM cable is a right angle device that turns 90 degrees toward the rear of the unit. I wish to mount a 696 in an Air Gizmos panel dock, and mount the XM antenna on the firewall. Problem is the XM antenna cable is not long enough to reach from the firewall to the panel. I have 2 options:
Cut the antenna cable and splice in an extension. This is the least preferred method.
I did find an adapter online which is just the ticket (almost):
http://www.texascyclechrome.com/mini...garmingps.aspx
However the description says "Special circuitry inside the adapter puts the GPS in charge mode." I don't know how this will work with the XM antenna. Does anyone know if this adapter would work?
Any other ideas?
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 04-13-2010, 07:11 AM
mburch's Avatar
mburch mburch is offline
You know it comes with an extra six-foot extension cable, right?
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 04-13-2010, 06:55 PM
flickroll's Avatar
Yep, but is is a straight connector. It needs to be a 90 deg connector...
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 04-13-2010, 08:01 PM
mburch's Avatar
For what it's worth, all the ones I've seen have 90-degree connectors... but it's possible they changed it.
good luck,
mcb
Matt Burch
RV-7 (last 90%)
VAF #836
Old 04-13-2010, 08:38 PM
flickroll's Avatar
Matt, have you seen one with a 90 degree male connector? All I have seen is a 90 degree female connector.
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 04-14-2010, 07:37 AM
mburch's Avatar
You mean like this?
It's hard to tell from the picture, but I checked the engineering drawing and it definitely has 90-degree connectors on both ends. There's one included with every 696, or you can buy a replacement here: https://buy.garmin.com/shop/shop.do?pID=1237
good luck,
mcb
Matt Burch
RV-7 (last 90%)
VAF #836
Old 04-14-2010, 09:15 PM
flickroll's Avatar
Thanks Matt! Been looking for that!
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
