Old 02-10-2006, 07:24 AM
Scott DellAngelo Scott DellAngelo is offline
Default Inspection Questions??
My 9A is just about done and I am thinking about trying to schedule an inspection. Of course I have all sorts of work travel trips scheduled so that makes things tough. Anyways I would like to schedule it, however I want to be sure I will have everything covered ahead of time, or can have a schedule to make sure that everything is covered.
I have the registration done and the card back. I have all of the other forms from the FAA. Are there anymore that need to go in, or just have them all filled out and ready at the inspection?
What needs to be removed from the airplane? I know cowl and wing access panels, emp fairing, and such, but what about seat floors, baggage back wall, flap actuator covers? (I will also ask the FSDO and see what they say)
Pitot/Static/Transponder check - I am inside O'hare's 30NM veil so I know I need it, but scheduling wise must that be done prior to FAA inspection?
A POH, flight test plan, anything like that that needs to be done and waiting for the inspection? If so what needs to be in them? I will have my laptop with lots of pictures and builders log for sure.
I know I need to have weight and balance done and have logbooks. Is there anything yet that really needs to be in the logbooks or just have them?
Scott
#90598 - Should be weighing it tomorrow
N598SD reserved
Old 02-10-2006, 09:26 AM
dan's Avatar
dan dan is offline
Default Ask the DAR, dude!
Your DAR may say otherwise, but generally speaking -- if it can be removed, it should be. Give your inspector an easy time inspecting EVERYTHING. No doubt your workmanship is top notch, but you never know.
Only the transponder if you're VFR, or the full boat if you're IFR.
You're asking us what your DAR wants. Ask your DAR, dude!
There is only one entry required in the airframe logbook, and that's your own signoff. Most DARs that I'm aware of will help you make that entry if you haven't already. My DAR brought a sticker entry for the logbook that I just signed.
Again, call your DAR and ask him/her these questions. Your DAR will help you with paperwork and requirements. That's a big part of what you get for paying for it!
)_( Dan
Old 02-10-2006, 10:31 AM
f1rocket's Avatar
f1rocket f1rocket is offline
Here's what I did with our local FSDO.
http://www.pflanzer-aviation.com/FirstFlightPrep1.html
Randy Pflanzer
Greenwood, IN
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 02-10-2006, 11:44 AM
Excellent Randy, thanks. I plan to use the FAA if possible (let's see ~$500 versus free, easy choice). At any rate I do have a call in with them but I wanted to get a feel for the mileage from others that have been there before. I find it odd that it seems the FAA wants it basically ready for flight and DAR's want EVERYTHING taken out. I certainly do not mind someone finding potential problems, but I would rather let my tax dollars pay for the inspection and not pay the taxes plus pay an inspector.
Scott
Edit: To follow up for others benefit/knowledge. I spoke with my FSDO and he said cowling off ONLY. Otherwise airplane should be ready to fly, everything on. No need to have static/transponder check done before inspection (i'm really just wondering about the scheduling of what if I cannot get it done first). He said have all paperwork ready and filled out but nothing else needs to be sent in. They want at least one hour of engine runtime prior to inspection.
Old 02-10-2006, 03:13 PM
Mel's Avatar
Mel Mel is offline
You said it yourself, the FAA inspector only wants to see under the cowling. Yes, his "inspection" is free, but how much can he inspect. That's the big difference between the FAA and a DAR. I've been doing Airworthiness inspections for 6 years and have yet to find one with no discrepancies. I've seen a lot of VERY nice airplanes, but not the "perfect" one. IF you have a discrepancy, you want to find it in the hangar, not on the first flight. I have no problem with a person having the FAA do the certification. Just make sure you have every jam nut tight, all safety wire in place and everything in order.
Good Luck, Mel...DAR
