Old 04-11-2010, 10:51 PM
KayS KayS is offline
Default tail wheel weldement RV-7
Hi, i'm on doing the RV-7 aft fuselage and i have a problem with the wd-409 weldement. there is the weldement part that is bolted/riveted between the two most aft bulkheads with a long steel tube that holds the tail wheel. the problem is that i can't get out the tube. that could be necessay later on to ship the airframe in a container.
did anyone had similar experiences? what to do here?
thank you guys...
Kay
Old 04-12-2010, 03:46 AM
N941WR's Avatar
N941WR N941WR is offline
Kay,
Drill a hole in the bottom of the fuselage large enough so you can get a socket on the nut that holds the tail spring in place.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-12-2010, 05:14 AM
dlloyd3's Avatar
dlloyd3 dlloyd3 is offline
Default WD-409
My tailwheel spring and the wd-409 mount were very tight. Van's suggested tapping on the spring with a brass hammer. They did not understand how tight it was. I ended up clamping the mount to a bench and twisting the spring. A little at a time it was twisted apart. There was no corrosion. I worked on both parts with some emery cloth before reassembling.
One of the main gear legs was very tight in its' mount as was one of the bolts. Someone is not paying attention to tolerances before shipping.
Dave
M20C
Old 04-12-2010, 08:51 AM
Hey Dave, thank you... how did you twist the spring? i don't want to use some brute force here to avoid bending or twisting the weldment. i tried the hammer method already but it is really to tight...
Old 04-12-2010, 08:56 AM
Sid Lambert Sid Lambert is offline
I used a deadblow hammer to knock it out. Took 50 or so hits.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 04-12-2010, 09:55 AM
dlloyd3's Avatar
Default Twist & shout
I twisted the tailwheel fork by hand. Maybe had a towel around it so the edges would not cut me. It moved a little just before I was about to give in. It was difficult to clamp that odd shaped mount to the workbench tight enought to stay put.
Previously I did pound on it with a 3 lb. hammer and bronze bar about 50 times without result.
Dave
M20C
