Old 04-09-2010, 01:13 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default Cockpit Floor
Folks,
I did not want to use carpet on my -6a so used some kind of foam and it def did not work well. I'd like to use something like a spray or brush on sound deadener that would also withstand shoes, boots, etc. The foam stuff had alum plates attached but again not a good idea.
So, what is everyone doing for this excluding carpet??
Jerry Cochran
Sherwood, Oregon
RV-7a 707DD Bot from David Domeier 12/01/11
Lycoming IO-360 Catto 3 blade Panel upgrade in progress
RV6a 18XP 1st flite 03/21/07 sold to Dale Walter 10/22/2011
Superior IO-360, Hartzell Blended, GRT/Dynon
Happily "autopaying" DR
"Suppose you were an idiot, and suppose you were a member of Congress; but I repeat myself."
Mark Twain
Old 04-09-2010, 01:57 PM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Floor boards
The planes I've rode in, the floor vibrates so much, it "tickled" my feet. I used an 1/8" hardwood plywood core and used contact cement to glue high density carpet foam on one side and a rugged outdoor carpet on top. The carpet will be easy to peel off if it wears out and replace with new.
http://www.mykitlog.com/users/displa...g=91817&row=29
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 04-09-2010, 02:53 PM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by Jerry Cochran View Post
........So, what is everyone doing for this excluding carpet....
Jerry,
I don't know what product is out there that can offer better corrosion protection and a very durable surface than Akzo epoxy primer. That's all I use for "carpet and upholstery" and short of using nothing at all, you can't build much lighter than that. This photo shows over 5 years of service. Every now and then, I'll use an MEK soaked rag to clean up stains and dirt. Don't try that with rattle can primer. For me, sound deadening qualities are not necessary nor am I interested in listening to music when I fly. We have to use headphones anyway and my Telex Stratus headphones take care of ambient noise even though 95% of the time I fly with the ANR turned off. YMMV.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 04-10-2010, 11:18 AM
Part of the problem I hate is that carpet will pick up and hold every little piece of junk or FOD that is around then your shoes transfer them to the forward part of the seat cushion as we old guys struggle to get out of the 6-7's. Easier to clean/vac plain alum I guess.
Guess I'll just forget the carpet/foam and go with bare alum and put up with the "tingle" Mike just referred to. Reminds me of my old Triumph bike that would put your hands to sleep at certain r's... Then there are those shakin'/quakin' Harleys... Not to start anything here...
Jerry Cochran
Sherwood, Oregon
Mark Twain
Old 04-10-2010, 03:03 PM
Marine grade upholstery vinyl glued over wood might work. That stuff can take a beating and won't hold dirt. Just a thought.
Colin P.
RV-6A #20603
Complete 5/10/19
PP SEL / A&P
Old 04-10-2010, 03:23 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I too, remember my 67' Triumph Bonneville. The fact that Harleys tend to get uncomfortable on long road trips (why so many are trailered to Sturgis); and why I finally put some FAA approved matting on the RV floor with light carpet, as well as using the ANR feature of my Telex digital headphones..
There are some reasons to "rough it", but I say why? My heavier RV beats a bunch of lighter weights anyway.....
Note: The fire resistant matting was from a travel trailer accessory store.
L.Adamson -- RV6A
Old 04-10-2010, 04:08 PM
plehrke's Avatar
plehrke plehrke is offline
Default Went to air craft interior aisle at Kohl's
I bought 2 heavy duty black bath floor mates. Tack them in with some velco. I pull them up every couple months and shake out or wash. Floor still looks like it was just painted after 3.5 years and 350+ hours.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 04-10-2010, 06:12 PM
Greg Arehart's Avatar
I put in pieces of 3/4" foam padding (ACS) cut to fit and then laid a piece of Al sheet on top, also cut to fit. The Al slides under the bottom side longeron, which holds it down (gotta do some test fitting and trimming to get this right). The center side of the Al is bent 90 degrees and slides down next to the center console. I drilled some holes in the "tab" of the Al to fit over the screw heads in the center console. This stays in place perfectly, giving me a "sandwich" of Al (skin) - foam padding - Al (floor) which is relatively easily removable. On the Al floor, I put a patch of skateboard fabric (like wing-walk, cheap at the skate shop) to keep my feet from slipping. I notice very little vibration on this floor.
greg
Greg Arehart
N 7965A
Old 04-10-2010, 07:32 PM
Shockwave's Avatar
Shockwave Shockwave is offline
3M makes a Rubberized Undercoating that I found at a local autostore in a spray can. It's advertised as corrosion protection, sound deadening and insulation to cars, trucks and RV's.
It has a rubbery texture, not unlike the wing walks. It says it can be used over primer in case one is worried that it could attack aluminum.
Chanler Childs
RV-8A
Empennage complete
Building wings
Old 04-11-2010, 03:44 AM
Default My experience
My experience is very satisfactory. I bought the black rubber/foam material and carpeting material from Becki Orndorf (sp?) along with the rest of the upholstery material and it has worked out great for 6 years in our RV-6A. I qualify for the senior discounts many times over and I'm currently 10-15 pounds overweight (I'm working on it) but I find the carpet and 3/4" thick foam gives me good traction, freedom from vibration, good sound proofing, excellent wear resistance and protection against lower fuselage skin damage from dropped tools, etc. The black material is the same height as the floor stringers and the carpet is glued across the floor stringers and foam. It vacuums nicely and tends to minimize FOD migration. I really think you should reconsider the carpeting bias.
Bob Axsom
