Old 04-09-2010, 10:00 AM
prkaye prkaye is offline
Default level flight attitude on the ground
For an A model, is "level flight attitude" the same as the airplane sitting on its wheels on a level floor?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-09-2010, 10:08 AM
647jc's Avatar
647jc 647jc is offline
Not really. Level flight attitude will also vary according to airspeed and load. If you set your artificial horizon pitch to level when on the ground, it will probably not be correct when in level flight. Also, for my RV9-A, if I set the horizon pitch to zero at 150 mph and then accelerate to 180, the pitch indication will be way off. Slower you go the higher the nose will be.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
Old 04-09-2010, 05:44 PM
aerhed aerhed is offline
If your looking for weighing level, no. That's usually a canopy sill, doorsill, or a level line (cessna uses a couple screws several feet apart).
Old 04-09-2010, 09:11 PM
rvbuilder2002's Avatar
I think it is covered in section 15 (but I might be wrong)
Leveling reference is with the airplane level at the canopy rails / main longerons.
This requires spacing the main wheels on a 7A or 9A higher by approx. the thickness of a 2X4. You can do the fine adjustment by adding or removing air from the nose tire.
Scott McDaniels
Hubbard, Oregon
Old 04-10-2010, 12:01 AM
Camillo Camillo is offline
I also guess that originally the ground attitude would have been equal to the level flight attitude and that after the SB regarding nose wheel and the subsequent higher nose clearance, the airplane assumed a slightly nose up attitude.
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 04-10-2010, 11:46 AM
647jc's Avatar
The nose wheel SB should not affect nose height or ground attitude.
Joe Condon
Ankeny, Iowa
Old 04-11-2010, 12:32 PM
Joe is correct. Changing the nose for while complying with the SB does not change the ground attitude at all.
Scott McDaniels
Hubbard, Oregon
