It's very important to make sure that you look at
every single sensor in the Global Settings on your Dynon.
I thought that I had everything set properly, but missed my fuel pressure sensor. The carberated version is different than the FI sensor. I was showing 9psi on my FI engine
A buddy missed setting his units, and couldn't figure out why his altitude was indicating 300 when he KNEW that he was at 1000'. (He was set to metric/meters)
As for calibrating instruments, it's probably more important to watch trends rather than specific numbers. If your oil temp is running 195* and next flight it runs 125*, you might have something going on...
