Old 04-07-2010, 10:34 AM
pilot28906 pilot28906 is offline
Default Drilling Out Tank Rivet
How difficult is it to drill out a tank rivet that has benn sitting for about a week (wet set)? I noticed one I drove on Friday has the shop head missing. Looks as if the shop head broke off right at the rib dimple hole. Does normal proceedures work OK? Any trouble getting the rivet out with the proseal set? I don't want to make matters worse but think this rivet probably needs to come out.
John Johnson
Murphy, NC
RV7
Old 04-07-2010, 10:39 AM
danielhv's Avatar
danielhv danielhv is offline
I assume its on the skin to baffle joint? Me personally, i would replace it. Shouldnt be a big deal as long as you DID put a bead of proseal along the inside joint per the plans. I'd drill it out, clean it up, and make sure you get some proseal under the mfg head of the rivet.
Old 04-07-2010, 10:46 AM
Sorry, it is a skin to rib joint.
John Johnson
Murphy, NC
RV7
Old 04-07-2010, 11:22 AM
mcencula mcencula is offline
Default No problem
It'll be no problem. Barely any more difficult than a regular rivet.
Good luck.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
Old 04-07-2010, 11:40 AM
snoopyflys's Avatar
snoopyflys snoopyflys is offline
Default Non Issue...at least for me.
I had 4 missing shop heads on my tank (ugh!) that I missed initially and caught during my final inspection before closing up the tank. As Daniel said, make sure to clean the hole up and get plenty of sealant in and around the hole as well as the new rivet. Also, make sure you are not driving the rivet too long. I found that I was doing this and with a Tungsten bucking bar and a 3x rivet gun, those 3.5s mash pretty quick.
Dan Schultz
=VAF= Annual Paid Subscriber
VAF #1446
Slow Building - 7A Tipper
Last edited by snoopyflys : 04-07-2010 at 11:41 AM. Reason: Correct previous poster name.
Old 04-07-2010, 04:38 PM
Talking
Thanks for the info. I will get this one out and a new one in.
Great Forum!
John Johnson
Murphy, NC
RV7
