Old 04-07-2010, 08:36 AM
Camillo Camillo is offline
Default First wing fit: shall I use NAS bolts?
Hi.
I am about to fit my wings on the fuselage and heard terrible stories about NAS bolts fit.
I was wondering if it is necessary to use them for a first fit (cutting the hole in the rear spar, cutting the fuel tube, making the hole for flaps, etc...) or if it is possible to use standard nuts. That way I guess it would be easier to place them.
Second question is: if I can use standard nuts, which are a subsititute for the NAS? NAS1304-50 may be changed with AN4-50. Isn't it? And NAS1307-50? They are 14/32'' bolts. Are them a AN3?
Thanks.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
Old 04-07-2010, 08:48 AM
rv9av8tr's Avatar
rv9av8tr rv9av8tr is offline
Default Wing taper pins
Just go to Lowes aircraft supply and buy 3 - 7/16" dia 4" long stainless bolts, grind the threads off and taper the ends to make guide pins.
The "trick" to eventually putting in the NAS bolts will be put them in the freezer and use something like "lubriplate" grease.
The SS taper pins are plenty snug for initial wing fit up.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
Old 04-07-2010, 08:49 AM
Jim Percy Jim Percy is offline
NO!!! Use hardware store bolts, preferrably with the threads ground off. There is no need to use nuts at all, just use the bolts as pins.
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
Old 04-07-2010, 10:08 AM
apkp777's Avatar
apkp777 apkp777 is offline
I agree with Percy. I used hardware bolts, no nuts for the pre-fit.
Tony Phillips
N524AP, RV 9 (tail wheel)
Old 04-07-2010, 10:09 AM
apkp777's Avatar
My wing bolts went right in with little effort (final installation). I used Boeshield T-9
Tony Phillips
Old 04-08-2010, 06:44 AM
Thanks to all.
I am about to order 4 AN4-50 and 4 AN7-47 (cheaper than the -50s) cadmium plated bolts from Spruce. No nuts.
Do you think that 4 & 4 (instead of 8 + 8) will be enough?
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
Old 04-08-2010, 09:29 AM
Yes. (cheap filler here to make message more than 10 characters)
Jim Percy
SoCal
FFI Wingman
RV-7A, XP-O-360
Old 04-09-2010, 06:23 AM
prkaye prkaye is offline
I'll go against the common grain here. I used NAS bolts, and put all of the close-tolerance ones in during initial wing fitting. I just wanted to be absolutely sure they would all go in... would be MUCH easier to fix a problem now than later. I then bought fresh NAS bolts for final wing attach. Not really that much extra money to buy fresh bolts in the grand scheme of the project.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 04-09-2010, 03:21 PM
Phil, your airplane looks really good!
And thanks for your input.
Ciao.
Camillo
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
