Old 04-07-2010, 05:50 AM
N661DJ N661DJ is offline
Default FAA Requirements
Quick question:
I have a friend with a recently purchased RV7A, 180HP. CS prop. he is low time 200hrs. A good Pilot.
Does the FAA require a "Complex, high performance" "check out", "sign off" by a "Cert. Flight Instructor" ?
Old 04-07-2010, 05:54 AM
Sid Lambert Sid Lambert is offline
No, the airplane doesn't even meet any of those categories but even if it did it's experimental so it's not required. The insurance company on the other hand may require something more or entirely different.
Sid Lambert
RV-7 Sold
RV-4 - Flying - O-320 Fixed Pitch - Red over Yellow
Old 04-07-2010, 07:28 AM
jnorris's Avatar
jnorris jnorris is offline
Originally Posted by Sid Lambert View Post
....but even if it did it's experimental so it's not required.
Sid,
That's not universally true. Most (but not all) operating limitations for experimental aircraft include the following language;
"The pilot in command of this aircraft must hold a pilot certificate or an authorized instructor's logbook endorsement. The pilot in command must meet the requirements of ? 61.31(e), (f), (g), (h), (i), and (j) as appropriate."
Note that the endorsements called out in 61.31 are specifically required. This means that, if the aircraft meets the definition of a complex, high performance, or a tailwheel airplane the pilot will need the endorsements.
Some older operating limitations may not include this language, but your second comment about the insurance underwriters will come in to play at that point so it won't matter.
Cheers!
Joe
Old 04-07-2010, 07:44 AM
JDRhodes JDRhodes is offline
A 180 HP anything is not high performance per the FAA definition. This one is complex due to CS prop and flaps.
If he's never flown anything with a CS prop, he probably needs to ride with a CFI in something that has one and get the endorsement. Shouldn't take more than an hour.
Jeff Rhodes - Taylorsville, GA
RV-9, 7 - going fast
BC-12D - going slow
jrhodes@v1salesmgt.com
Old 04-07-2010, 07:47 AM
Default insurance
... and insurance underwriters quoting RVs don't care or ask about the HP, the prop, or whether the pilot has any of the required endorsements. So that won't matter, so long as he's legal per Part 61.
BC-12D - going slow
Old 04-07-2010, 07:49 AM
airguy's Avatar
airguy airguy is offline
It doesn't matter - until there is a claim. Just because they didn't ask when you initiated the coverage does not mean they won't deny the claim later if you don't meet the requirements. Ask - do not assume.
Old 04-07-2010, 07:52 AM
scard's Avatar
scard scard is offline
It is NOT complex without retractable gear.
Scott Card
CMW E-Lift
Old 04-07-2010, 08:02 AM
Auburntsts's Avatar
...he probably needs to ride with a CFI in something that has one and get the endorsement.
No such thing. Like Scott pointed out, you only need a complex endorsement if the aircraft has retractable gear, flaps, and a controllable pitch prop (or in the case of a seaplane, flaps and a controllable pitch propeller). Take away one of the 3 and no complex endorsement required.
The high performance endorsement for engines over 200HP is a seperate requirement altogether and is in no way tied to the complex endorsement.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
Old 04-07-2010, 08:16 AM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by Auburntsts View Post
No such thing. Like Scott pointed out, you only need a complex endorsement if the aircraft has retractable gear, flaps, and a controllable pitch prop (or in the case of a seaplane, flaps and a controllable pitch propeller). Take away one of the 3 and no endorsement required.
And "High Performance" is anything OVER 200 HP. So if you have a 95 MPH Steaman with the stock 220 HP engine you need a High Performance (and Tailwheel) Endorsement to fly it.
BTW, most endorsements have a Grandfather clause.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 04-07-2010, 08:59 AM
Originally Posted by Jamie View Post
For an airplane to be complex it must have ALL THREE...an in-flight controllable pitch prop, flaps and retractable gear.
I was thinking for some reason that it had to have just 2 of the three. You may be right.
BC-12D - going slow
