Old 04-06-2010, 11:26 PM
Bob Redman Bob Redman is offline
Default Tip: Taildragger Damage
G'day folks,
First post.
Thanks to the generous and sound advice on this forum, until recently my errors have been small.
Now I would like to help prevent others from making the same large mistake that I have made.
If you are transporting a taildragger to the paint shop or hangar, and you have not:
fitted the empenage, and
secured the tailspring and tailwheel with bolts, through the vertical stabiliser spar, and bulkheads;
then please support the fuselage and tail wheel clear of truck or trailer using cushions as load spreaders for the support (I used a sawhorse) under the rear two bulkheads (F711 & F712) and the tie down strap over the top.
On reflection, use cushions and sawhorse (or equivalents) whether or not the empenage and tailspring/wheel are fitted.
I had removed the empenage some months ago and had not replaced the three bolts which secure the rear tailspring weldment to the rear bulkhead.
I noticed the bouncing as I followed the tilt-tray truck, and immediately knew my mistake. Fortunately the damage was minor, confined to the rear bulkhead (F-712), my pride, and a 5 week delay. The bulkhead has been replaced with new parts from Van's, and the rivets and bulkheads re-painted. Now no one will know except you and me.
Bob Redman
Newcastle NSW Australia
RV-7
Financial until 2029
Old 04-07-2010, 07:14 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Really great post Bob! I made this same mistake years ago when I transported my -8 to the airport, and like you, saw the bouncing and stopped things before they got bad - but it could easily wrinkle the skin and bulkhead!
We just took our RV-3 out of the jig, and since the tail wheel spring is not yet drilled to the aft bulkhead at all, I pointed out this potential for damage to Louise - we have to handle it carefully until those holes and bolts are in.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-07-2010, 10:15 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!!!!
Originally Posted by Bob Redman View Post
G'day folks,
First post.
Bob, welcome to the force, and thanks for the advice/warning.
Great way to have a first post
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-08-2010, 12:21 AM
Default Thanks
Gents,
Thanks for the welcome, and thanks too to Mr Doug Reeves for his efforts - much appreciated.
Regards,
Bob Redman
Bob Redman
RV-7
