Old 04-06-2010, 05:54 PM
larryj larryj is offline
Default aircraft hardware - the good stuff
I'm finally getting around to putting some pieces together that will stay that way; so am ready to start using real fasteners. My intention is to optimize each fastener application; using shear bolts in shear applications and tension bolts in tension applications. I thought I had a pretty good collection of books/documentation but I'm coming up short on what I (think I) need. For shear and most routine spots I'm wanting to use NAS6203 / NAS6204 (replacements for NAS1103 / NAS1104); Aircraft Spruce and other have these and info is readily available. For tension spots (engine mount) I'm thinking NAS626 or MS9036 but I cannot find any good info on them. Anyone know where I can look / call ??
Larry E. James
Bellevue, WA
Husky A1-C
Rocket (under construction)
Old 04-06-2010, 05:58 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Try these guys http://www.gen-aircraft-hardware.com/
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
Old 04-06-2010, 06:02 PM
jtrusso jtrusso is offline
Default Not sure if this is what you're looking for but....
This might help:
MILITARY SPECIFICATION SHEET
BOLT-MACHINE, 12 POINT HEAD, HEAT RESISTANT STEEL, .375-24 NS
http://tinyurl.com/ykxlhfd
-John
Flying a Glasair I FT
Planning to build an RV...someday
Old 04-06-2010, 07:17 PM
Why not use the fasteners that the plans call for?
