Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 04-06-2010, 06:28 AM
pierre smith's Avatar
Default Help: Garmin 430 course/track line...
Hi guys, my 430 always draws a course line from my location to the destination and I can't find the instructions to change it to a track line, like my 496, where it always draws a line from my present position to the destination. Is it even possible with a 430W?
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 04-06-2010, 06:41 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
On my 696, I can hit the "direct to" button, and then "enter" to activate the present waypoint or airport that will be flashing. Looking at the quick guide for the 430, it looks to be the same. You can get the quick guide by googleing 430 & instructions.
L.Adamson --- RV6A
Old 04-06-2010, 06:47 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Don't tell anyone but my understanding of all the capabilities of the 430W are probably in the under 5% area. So what I do if I get off the line is hit the GoTo button then Enter twice to recenter the line.
Is there a better way? Possibly.
Old 04-06-2010, 06:58 AM
mburch's Avatar
mburch mburch is offline
It sounds like you have enabled the "Bearing Line" option on your 496, which causes the unit to draw a line from your present position to the active waypoint. This feature is kind of a holdover from marine and land-based products, and isn't supported in the panel-mount units or the newer portables.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 04-06-2010, 08:21 AM
BlndRvtr BlndRvtr is offline
Help educate me here. What is the difference between the course line and the track line?
I thought I knew the 430/530 series fairly well.
George
Old 04-06-2010, 01:02 PM
Default Matt is correct.....
...it is the 'bearing' line. I've pressed D-to and hit enter quite a few times. I'd really rather it draws the bearing line from my present position but I guess it can't do it.
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 04-06-2010, 01:41 PM
vic syracuse vic syracuse is offline
Super Moderator
Pierre, I have never seen a course line on the 430. When you hit "direct to enter" it draws a line from current position to the waypoint. If the airplane gets off of that line, it is displayed as being off of that line. Nothing more.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 04-07-2010, 06:19 AM
Sticky1's Avatar
Sticky1 Sticky1 is offline
Vic
Unless you fly IFR
Old 04-07-2010, 01:52 PM
Default Well, I spoke to Garmin....
...a little while ago and they said that you can't do that with the 430W and he believed that it had to do with certification. He mentioned that they have more leeway with the X96 handhelds, since they're not certed.
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
Old 04-07-2010, 02:00 PM
Default Vic, check your PM's..
..kind Sir
Best,
Pierre Smith
RV-10, 510 TT
Louisville, Ga
Dues gladly paid!
