Old 04-05-2010, 08:36 AM
Gregg Brightwell's Avatar
Gregg Brightwell Gregg Brightwell is offline
Question Acid Etch...
Good morning all,
I guess this thread is more 'general' than any other category. I recently purchased a 2nd hand wing kit, and a few of the ribs have some light surface corrosion, but nothing that can't be corrected (I think). I have been using a scotchbrite wheel on a dotco, and it works, but it is very time consuming. (a little at the time)
I remember a little about acid etch from college, (A&P classes) but don't remember everything.... What products out there have you all used to remove light scale / corrosion from aluminum?
I saw a product on Spruce from Stewart that appears to be more eco-friendly than some, but does it work as good?
Please help! I want to remove all traces of corrosion before I prep and prime these parts. I will reject and replace the parts that won't 'clean up', but don't want to reject anymore than I need to.
Thanks!
Gregg
Gregg J. Brightwell
Benton, KS
CFII/MEII, ATP, AGI, A&P
-4 Emp and Wings complete!
Fuselage out of the jig!
www.mykitlog.com/gbrightwell
Old 04-05-2010, 09:01 AM
Phil's Avatar
Phil Phil is offline
Hi Gregg,
I scrub the corrosion off with a scotchbrite pad and then treat it with an Alodine Pen.
Then I cover it with some type of rattle can primer. Typically SEM Self-Etching. I can pick it up at a local auto paint supply house.
If there is a spot that requires too much scrubbing for my arm to handle, I use one of these on a drill. I've got some that are Aluminum Oxide and they make quick work of it. (Then of course I treat it with the alodine pen as before.)
Phil
Old 04-05-2010, 09:22 AM
Default acid etch
Phil,
Yep, I scrub all the bad stuff off, then hit it with an alodine pen. Just looking for a way to do the same with less effort I spent 4 hours yesterday and only cleaned 4 ribs (perfectionist). There has GOT to be a better way... I need some good acid etch to 'eat' the bad stuff.
Gregg
Gregg J. Brightwell
Benton, KS
Old 04-05-2010, 09:43 AM
Phil's Avatar
It sounds like Alumiprep is what you're asking about.
It will etch the aluminum, but you should still scrub them down with a scotchbrite pad. Then of course you have to treat the part with alodine.
BTW, the Alodine Pen can be accelerated by applying some heat from a heat gun on low settings, hair dryer, or space heater. It's perfectly acceptable to force-dry it with hot air.
Phil
