Slow cranking w/Odyssey & MagnaFlight solved w/B&C starter
From the beginning, I always experienced slow cranking on our 0-360 with an Odyssey PC-680 battery and MagnaFlight MZ6222 lightweight starter. I would have to bump the starter to get the prop past compression. In 3 years, I purchased 3 Odyssey batteries because when they got a tad weak, (12.1 v with master switch on) and it was cold, the engine would not crank. My research indicated that some others were having the same problem, and solutions ranged from changing to a larger amperage battery to increasing the charging voltage from 14.3 to 14.6, (the latter I did to no avail). I was bemoaning my problems to Bill @ B&C while ordering a new Odyssey with a fresh manufacture date when he asked which starter I had. When I told him it was a MagnaFlight, he said it was without a doubt the problem, & was not even a good boat anchor (too light). I followed his directions and confirmed the starter was drawing up to 600 amps and the voltage at the starter dropped to 8.4v, when it should be drawing 250 to 300A @ 10+V. He explained the MagnaFlight was a permanent magnet design, cheaply made, versus his being series wound, with ball bearings and metal gears, @ 10.2#.
So, in July 2009, I purchased a B&C BCS20C-149 for $567 delivered. The B&C starter spins the engine twice as fast with no bump & the voltage only drops to 10.7v. I did not take the time to set up my video camera to check the amperage draw, but it has to be significantly less. In fact, I may have the only hybrid RV since I pull the mixture during flight & fly using the starter, until the battery drains down, then I restart the engine! I waited until now to write my report to see if 40 degree weather would slow the cranking. I am happy to report there is no difference. I now have two spare perfectly good Odyssey batteries that I use to power my GPS simulator at home. Case closed!
P.S. There are many factors that can affect cranking, so do not assume a new starter will solve your problem until you have ruled out everything else or have done a draw test.
