04-04-2010, 02:15 AM
Have to be "Sharpies"?
Hi all,
A builder visited my project today, notice I wasn't using "Sharpie" Brand markers. He advice I stop using "non-Sharpie" because other brand might have ingredients that damages metal. He also advice to scrub away any markings I made with the non-Sharpies and spot prime those spots.
He built his 7 years ago and I wonder if anyone heard similar information. I honestly never heard of it before, at one point, I did consider import some Sharpies as they don't sell them here in Hong Kong, but I thought about it at the time and couldn't see what harm can it do by using a different brand.
Any feedback is greatly appreciated!
Hank
Hank Cheng
RV8 Super Slow Build Kit
Titan IOX360, Catto 3 Blades RV prop, Full Dynon everything + Garmin GTN650
First RV in Hong Kong
First Homebuilt aircraft registered in Hong Kong "B-KOO"
Completed RTW journey in 2016
Built with a group of High School Students
Aircraft donated to the Hong Kong Science Museum
In memory of Michael Tam
04-04-2010, 02:51 AM
Sounds like utter nonsens to me. The only thing that can damage metal is some corrosive agent or graphite. Markers are made to be safe to be eaten by babies, surely they are safe to use on aluminium.
04-04-2010, 03:51 AM
That's probably a bit too paranoid. But... Consider that other similar pens are likely to be ok, but we have many years of experience with Sharpies, so we know them to be ok. If you can, find a type of pen that's available that others have used with no ill effects. Otherwise, you are doing a chemistry experiment.
Indeed, graphite, metals, or non-neutral pH would be the main concerns with pen ink on aluminum. Not necessarily the same concerns for a baby's digestive system. Many foods we eat have non-neutral pH, i.e. are acidic or basic, and while they're safe for us to eat, they will easily corrode aluminum. You would be wise to keep the orange juice away from your airplane, and keep your kid from eating the Sharpie! Incidentally, while not advised, junior will also tolerate graphite better than your airplane will.
04-04-2010, 07:07 AM
And don't scrub!
Hank
Just use a little MEK on a cloth to remove those other marks; don't scrub!
04-04-2010, 09:02 AM
Metal contaminates
Ummm.... I didn't realize graphite was an "issue" on Al??? Metallurgically, how so? I know there are issues with ink marker pens relative to chlorides, which are prohibited for high strength applications of stainless steels, due to chloride stress corrosion cracking.
Long-EZ built 1985 -> Sold 2007
RV-9A; N539RV First Flight: 7/2010
RV-8A N468DL 40 hr Flight Test Program
Building Log: www.mykitlog.com/n539rv
APRS Tracking: aprs.fi/n539rv
2017 Paid
04-04-2010, 09:11 AM
There is a common fear of corrosion due to electrical differences between Al and graphite. It is the same idea that says carbon fiber composites against Al is bad, why you should have a layer of fiberglass over the carbon fiber.
there are some people that think it is an "old wives tale" i.e. unproven
nothing special here...
04-04-2010, 11:43 AM
Pilot
Avery Tools sells Pilot brand marking pens rather than sharpies and also ships them with their RV tool kits.
http://www.averytools.com/p-67-pilot-marking-pen.aspx
Originally Posted by Avery Tools Website
PILOT BRAND.Perfect for marking on aluminum and steel for drilling and cutting.Permanent ink will not wipe or rub off easily after drying.Extra fine point.Packaged 3 pens per pack -one each:Red,Blue,&Black.
mark
RV7 - working on wings (very, very slowly)
04-04-2010, 01:15 PM
I have used other brands although prefer blue sharpies - Van's training
I have used other brands although I prefer blue sharpies - Van's training. I wash the area with rubbing alcohol to remove the marking after it is no longer needed. Personally I would sweat the effects of paranoid cleaning more than the difference in chemical composition of the marker pen inks. The airplane was completed in 2004 but I continue to modify with aluminum and fiberglass for speed. No problems due to the use of other than Sharpie marker pens.
Bob Axsom
04-04-2010, 02:56 PM
Usually if you look closely and read on the packaging it should say "Archive Safe." This is suppose to mean that the ink is Ph balanced and safe for delicate documents and what not. I'm sure its good enough for sheet metal.
04-06-2010, 01:16 PM
Sharpie or non sharpie shouldn't matter. This probably comes from the issue of chloride in the ink. The chloride will react with certain metals which can cause cracking over time. Typically you have to watch out for stainless and titanium used in high stress or high heat applications. Aluminum isn't one of those metals. Most sharpies have chloride in them. I haven't actualy found one in any color but black that is certified chloride free. If you wan't one that is chloride free the sharpie will usually state that it is T.E.C. certified right on the pen next to the name.
Keith
