Old 04-03-2010, 01:08 PM
Shockwave's Avatar
Shockwave Shockwave is offline
Default top aileron rivets
How did those with a 7 or 8 kit rivet on the leading and trailing aileron skins to the spar? I have a few rivets in using the pneumatic squeezer and then a few more with a regular gun and bucking bar but I'm at a point where I can't get the bar on well. I'm thinking maybe a double offset backrivet set might work, but I'd like to hear everyone else's thoughts.
Chanler Childs
RV-8A
Empennage complete
Building wings
Old 04-03-2010, 03:54 PM
mcencula mcencula is offline
Default Bucking block
I designed a special bucking block. One of my friends cut it out for me on the wire EDM machine at work:
The square-ish hole in the middle fit onto a 1/2" x 2" x 6 ft steel bar which I slid through the length of the aileron:
Sliding the block along from rivet to rivet allowed me to install solid rivets on both the top and bottom surfaces:
Good luck!
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
