Old 04-02-2010, 02:31 PM
rph142's Avatar
rph142 rph142 is offline
Default Where can I find plastic AN plugs and caps
I am in the process of preparing to hang my engine, which means removing a christen inverted oil system and one design engine mount. I would like to plug all of the AN fittings with either a cap or a plug until I can re-install the inverted oil. Does anyone know where I can find these caps and plugs?
Rob Holmes
www.myrv3.com
N59LG
The minimum number of planes one should own is one. The correct number is n+1, where n is the number of planes currently owned. This equation may also be re-written as s-1, where s is the number of planes owned that would result in separation from your partner.
- Veluminati
Old 04-02-2010, 02:55 PM
hydroguy2's Avatar
what size and how many do you need? I have quite a few screw-on type #4's and maybe some slip on #6's. PM me your address and i'll send to you....it'll help clear my workbench Mine are for storage only, not pressure.
Old 04-02-2010, 03:17 PM
Default I have some
I have couple of each PD-80, PD-60, PD-40, one PD-66 and one B-592. Also two FC-8, one EC-10 and one EC-12. If you need any PM me your address.
Old 04-02-2010, 03:41 PM
rph142's Avatar
Thanks for the offers guys. I didnt realize these things had part numbers. I am going to need quite a few so I think I'll just get them from aircraft spruce.
Thanks again,
Rob
Rob Holmes
www.myrv3.com
N59LG
- Veluminati
Old 04-04-2010, 07:23 AM
David_Nelson's Avatar
David_Nelson David_Nelson is offline
Default Let your fingers do the walking
Hi Rob,
I got some from a local hydraulics supply house. They had a bucket that I could pick-n-choose from - for free!!
/\/elson
RV-7A Tip-Up
NW Austin, TX
