Old 03-31-2010, 12:26 PM
ryanturner's Avatar
ryanturner ryanturner is offline
Default Scotchbright wheel wear
I have been getting a lot of use out the scotchbright wheel I have mounted on my bench grinder, to the point of wearing a grove right down the center of it. While cleaning up the edges of the skins for the horizontal stabilizer this morning, I noticed that the groove has gotten so deep that the sides of the groove are making contact with the top and bottom of the skin and removing some of the alclad. The groove is about 1/8 inch deep.
I am still working on the first portion of the empennage kit, so this is still all very new to me. Is this normal wear for a scotch bright wheel? Should I be worried about the alclad removal?
Old 03-31-2010, 12:32 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
It might be too late for this wheel, but if you move the parts diagonally across the wheel you won't groove it. It will last for several airplanes this way. If you try the diagonal trick now with the groove in the wheel, you will wind up eating the part. When you can't move the part diagonally (due to its shape), try and use a different part of the wheel each time to keep wear even.
You can probably save your wheel by dressing it with an old file until it is flat across the front again. This will make a huge mess, but is cheaper than replacing the wheel.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 03-31-2010, 01:07 PM
Dan Langhout's Avatar
Dan Langhout Dan Langhout is offline
Default 40-60 Grit Paper on a block . . . . .
. . . . does a really good job of dressing down a wheel to get rid of a groove. I tend to use the 2-inch Scotchbrite wheels on a die grinder - and they groove terribly! The course grit paper on a block seems to remove material on the wheel without much effect on the sandpaper. I have used old files for this task but the wheel seems to wear the file as much as the file wears the wheel!
FWIW.
Dan Langhout
2020 =VAF= Dues PAID . . . . .
RV-7 N528DP slow build
First Flight July 26th, 2014
665 hours and counting . . . .
Now based at Moontown (3M5)
Old 03-31-2010, 01:54 PM
9GT's Avatar
9GT 9GT is offline
I like to have a groove in mine for polishing up the edges. When it gets too deep, I move over a little until its finally full of groves too deep to use. Then I dress it down and start all over again.
David C.
Howell, MI
Old 04-04-2010, 08:39 AM
rv7charlie rv7charlie is offline
After going through the same frustrations using the wheel, I discovered that a common belt sander clamped to the workbench works just as well (often better) than the wheel. I think I used 120 grit for most of the sheet stock, with a touchup using something finer if it still felt rough. For thicker stuff with deep shear marks, I'd use bigger grits to start. In addition, I found that I could clamp large sheets to the work bench & 'free hand' the edges with the sander. I used my 'standard' size (3"x21", IIRC) but a smaller one would obviously be easier to handle in free hand mode. If you want to try it, be sure to practice 1st on scrap. I found that you must be careful to hold the work so it's being pulled across the cutting surface; never pushed (causes it to chatter).
Charlie
Old 04-04-2010, 10:21 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Charlie
I constantly use my belt sander to make pieces nice and straight - but I always end up polishing the edges with the scotchbrite wheel (or disks on the angle grinder) to give a smooth edge. I'm not sure 120 grit would give me the amount of polish I like to see on edges. My preference of course.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 04-04-2010, 10:28 AM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
It was the same for me. I used two 1" belt sanders with different grits. And then the Scotchbrite wheel, or blue 2" scotchbright disks on an angled air grinder.
L.Adamson --- RV6A
