03-31-2010, 08:01 AM
Which warning/infos should be on panel?
I am ready to use the Decalpro to "print" on the panel.
I was wondering which are the commonly written warning and infos and need advice on the correct english spelling (since RV's are american machines, I would like to have all writings in english).
I can imagine the following:
1) experimental warning (see Van's placard);
2) EI FT-60 warning (i.e.: only rely to primary fuel gauges to determine fuel left in tanks: I will see on EI manual);
3) something like: aerobatics forbidden (see Van's placard?);
4) alternate static air located under the panel (is this right?).
I don't think I will add typical speeds, since they are depicted on the analogic A/S indicator (and on the Dynon EFIS, too).
More inputs?
Thanks.
Camillo
RV4 IO-320, Catto 3-blade, Christen, I-BILT
Flight time: 1 hour
Status: test flights
www.rv4.it
ROME, Italy
RV9A O-320 D1A, Hartzell C/S prop, slider, I-PRCA
Flight time: 350 hours
Status: SOLD
http://nuke.rv9.it
03-31-2010, 08:07 AM
I would say that you need at least what the Italian aviation authority requires and then whatever you think will help you in the cockpit .
Is "experimental " necessary in Italy ? In Canada we're not even allowed to display that if we wanted to .
Marc
1993 RV-4 C-GVMT
Formerly N144RS
SN 1444
03-31-2010, 08:11 AM
Camillo,
I did the minimum on mine but I'm in the States, so that may not apply to you.
One thing I wouldn't do again is label always hot circuits for the electronics as "Keep Alive". I've had more than one new passenger comment on that label.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
03-31-2010, 08:47 AM
Prop/power limitations
For ex, Sensenich O-320 2600 rpm lim, or some Hartzell prop 'avoid operations between xxx and yyy.
If you have a flop tube in only one tank, 'acro on zzz tank'
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
03-31-2010, 10:15 AM
I used DecalPro
on my panel and after a LOT of practice, the results were pretty good. On the "Experimental" disclaimer, I would just buy a commercially made one. I was never successful at making large complicated transfers with the DecalPro system, even though I tried MANY times...
YMMV
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
03-31-2010, 10:34 AM
OK to just have Van's experimental placard ? love to hear Mel's response
I was planning on just going with the words from the Vans placard, which has the words that I think come directly from the AC. "PASSENGER WARNING - THIS AIRCAFT IS AMATEUR BUILT AND DOES NOT COMPLY..."
So my question for Mel is, what is truly required beyond that placard?
For example, the EFIS has the airspeed limitations (and can even do the prop limitation). Is a "no aerobatics" placard required for a -9A?
I guess I was hoping that a well done POH with a limitaions section would avoid the need for lots of other placards.
Thanks for any info,
Dave Gribble VAF #232
Building RV-9A N149DG (slider, IO-320, IFR)
Restored and Flying Beech Super III N3698Q
Marion IA
Struggling with fiberglass
There is no sport equal to that which aviators enjoy while being carried through the air on great white wings." Wilbur Wright, 1905
03-31-2010, 03:47 PM
Thank-you for your answers.
It seems that for Experimental warning, an english warning would be ok (but I will translate it).
My RV is not aerobatic, so no need for that specific fuel tank warning.
And no need for propeller/RPM warning, since it is needed only for some O-360. My engine is an O-320. No particular limitation according to Hartzell or Lycoming manuals.
I have to add that I already have a separate breakers bar under the panel which is labelled for each stuff and it also states where the e-bus stuff is.
Maybe I can add a warning just above my EFIS, in front of me, "Nose wheel is only a taxi wheel and it is not intended for take-off and landing operations. Always keep nose wheel up until it is possible". Just to remind me that this is the real problem for an -A.
And maybe a warning for "this airplane is not allowed to fly in IMC conditions or in known icing conditions". I have a heated pitot, certified engine, TSO'd instruments and TSO'd radios, including IFR GPS (430W), DME and ADF. But in Italy an experimental is not allowed to fly in IMC (and even if it would, I will never fly in such conditions). Maximum allowed is IFR VMC.
It may be not necessary to write all on the panel. But I feel myself a child while building my RV and would like to add whistles and bell... Nobody will never know that not all was necessary ;-)
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
04-01-2010, 04:24 PM
HUMOUR
" This ride may cost you over $100k USD "
or
" This plane runs on fuel TANKS, not THANKS "
I like things like that on a panel. I think you have already worked out the needed warnings for your panel.
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
04-19-2010, 08:21 AM
I finally decided what to write on my panel.
Could one of you please review for me the spelling?
In particular, the word "maneuver" in the acro placard should be in plural?
Thanks.
Camillo
DO NOT RELY ON FUEL FLOW INFOS TO DETERMINE FUEL LEVEL IN TANKS
ADI FEATURES
MAX +/- 45? BANK ANGLE DISPLAYED (NO TURN RATE)
TRUE TRACK DISPLAYED (NO MAGNETIC)
PITCH ATTITUDE IS FOLLOWED BY VERTICAL SPEED
LIMITATIONS
NO AEROBATIC OR ABRUPT MANEUVER ALLOWED
NO IMC AND/OR NIGHT FLIGHTS ALLOWED
ALTERNATE STATIC AIR SOURCE LOCATED UNDER THE PANEL (PULL BLUE STRIP)
Flight time: 1 hour
www.rv4.it
ROME, Italy
Status: SOLD
http://nuke.rv9.it
04-19-2010, 09:00 AM
MANOEUVRE
MANOEUVRE (in the Queen's English)
NO AEROBATIC OR ABRUPT MANOEUVRES ALLOWED
Steve Hutt
West Sussex, UK
RV-7 G-HUTY (not flying yet)
( Tip-UP / TMX-IO-360-M1B / Hartzell 7497-2 / 1x LSE PLASMA III / Dual AF4500's / AF-Pilot AP / 695 )
