03-30-2010, 07:12 PM
Fat wires and the pull test
Generally speaking, if something doesn't work out the way it should on my RV project, I assume it's something I've done wrong. But this evening, I'm a little concerned that that may not be the case.
I was reinstalling the fat wires on the battery, to power up the Vertical Power 50 system and test out my long-running installation of the radios in N614EF.
When I dug the ground wire (from battery to firewall) out of the work cabinet, where I'd stored it since removing it a month ago, I notice one connector was missing.
This is the P9 wire, which I bought from Van's because I didn't really want to build these things myself. So for about $15 a pop, I figured what the heck.
I twisted -- slightly -- the other connector and gave it a slight tug and off it came!
Then I checked the P14 (battery to master), slight tug.... voila! Both ends.
I checked another Van's cable I had around -- a P14, I believe, and the connectors did not seem to twist off.
Because there's heat shrink on these things, you can't really tell much about their construction until they come off, but I see no signs of solder and no signs of crimping. It looks like they just slapped a connector on, slapped some heat shrink on, and mailed it out.
Is this the way it's supposed to be? It's got me a little spooked that I could've been flying around, and had some pretty important cables fall apart.
03-30-2010, 07:26 PM
Wiring
No, it's not the way it's supposed to be. Suggest you call Van's and advise them of the problem. They may have a bad batch on the loose.
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
03-30-2010, 07:52 PM
?The important thing in aeroplanes is that they shall be speedy.?
- Baron Manfred von Richthofen
RV8 under construction
RV4 - Sold
United B777 FO, Chicago
Aero Engineer
RV8
03-30-2010, 07:56 PM
Are these new, or some older ones? There is a SB on this, but it is a couple years old.
RV-8 108LF
03-30-2010, 08:46 PM
Originally Posted by Bill Wightman
I'm buying.
03-30-2010, 08:47 PM
Bought them last year. Will post a video shortly showing how easily they pulled off.
03-30-2010, 09:03 PM
I seem to remember that Van's provided a notice or service bulletin a year or two ago mentioning that they had a bad batch and that you should check them with a 50# pull test. My memory could be flawed though.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
03-30-2010, 09:12 PM
Well, here's the thing. Van's knows who bought these cables. Why not send out mail to those people to alert them. This is a pretty serious thing and I would think relying on people to go to the Van's site to see if maybe their product has a problem would seem an unreasonable burden on the builder.
The only SB I can find on it is this one. It's from October 2006. I purchased these last summer.
I guess my real problem is that someone was put in a job where he/she/it thought sticking a connector on a wire and sticking some heat shrink over it constituted properly construction technique. And that someone shoved it in the shipping container without likewise giving them a tug. Lousy quality control.
I just stuck a video up on the blog.
03-30-2010, 09:32 PM
Had the same problem a few years ago. Solution is simple. Solder the connectors.
03-30-2010, 09:35 PM
I tossed 'em out. I figure if this rather obvious defect slips through, I can't trust the quality of any aspect of it. I'll make my own, or order custom ones with a company I can trust -- B&C, for example.
