Tmx 0-360
Folks, I completed the TMX-0360 mated to Vans firewall kit with little mods except for the following:
Oil filler - too close to the mount. Solution was to get the heat gun out and bend the bugger a bit (per Mahlon). It's plastic and worked fine.
Tach sender was a problem and needed to be mounted on the firewall using Vans 12" tach cable.
Baffle - a beast no matter what engine you use.
Everything has attached with ease and I can't say enough about their support. One thing I would do next time is have them help me install the engine when they deliver. Their driver has done 100 installs and can use his truck hoist.
Go for it!
Doug Sims
Blacksburg VA
RV8 Flying
