Toasty relays
Folks,
I'm using 2 Infinity stick grips and the trim relay board from Inifinity as well.
Planning on wiring all stick switch functions in parallel and ganging the grounds from the rear stick to a disable switch as they recommend.
I'm concerned that if the flap switch on the rear grip is left in the up position and one should flip the front stick flap down switch that the opposite electrical inputs would fry the relays on the trim board. Or if opposite trim inputs will fry them. Same idea.
Anyone have a good understanding of that board, the relays and have any experience with this?
Jesse Bentley
N229Z - RV-8 - Flying - Livin' the dream!
