02-07-2006, 02:37 PM
VAF Moderator / Line Boy
Well - sort of...
Jim -
Your question is exactly why I have a glimmer of hope that I can fix my problem! I carefully used insulating washers for the Mic and Phone jacks in both front and back seats, because I knew that they shouldn't be grounded - BUT...I am pretty sure I didn't do that for my AuxAudio jacks (where I am gettign teh hum). I am goign to pull the jack away from the airframe and see fi the problem goes away...at least I can hope!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
02-08-2006, 05:06 AM
Noise from MP3 Jukebox
Dear Paul:
My guess is that you are powering the Jukebox from the aircraft power. If that is the case, what you are experiencing is Ground Loop noise. The ground potential at the audio panel's ground and the ground potential at the Jukebox ground are different. What you are hearing in the headset is that difference, amplified by the audio amplifiers needed to take the lower level signals from the Jukebox and make it large enough to drive your aviation headset.
To confirm, power your Jukebox by batteries and the noise should go away. If it does, you might want to take the power from your Jukebox at the exact same spot as the audio panel.
Let's see if we can solve this noise issue together.
Sincerely,
Mark Scheuer
PS Engineering, Inc.
Originally Posted by Ironflight
.....I'd do it the way PS Enginering says! My audio system has been perfect (done with shielded wires per their manual), with no whine or hum at all. Perfect, that is, until this weekend when I plugged in my MP3 Jukebox for the first time. You guessed it - got a hum! I can plug the stereo cable into the airframe jack, and no problem, but when I plug the other end into the Jukebox - Alternator whine (if I kill the alternator, the whine is gone)! It's not really that bad if I turn the music up, but that's not good for the ears!
Anyway, I talked to PS Engineering yesterday, to see if there is a "simple fix" (A filter or something), and alas - no dice. It's all magic, and probably has to do with a floating ground somewhere. Bottom line - do the very best you can to follow the installation manual to mimimize the chance of noise in the system. You're not going to know you have a problme until you are flying (you can't test it "all-up" until the wiring is finished), and at that point, fixing a wiring problem is WAY too hard....
I have much respect for Bob Nuckoll's and learned a lot from his book, but in the end, he doesn't have to fly your airplane - and you do!
I am going to check the easy stuff - the ground potential at the airframe jack - and then live with it (at least until I decide to upgrade to a stereo intercom...there's always more money to spend!  ).
Paul
02-08-2006, 06:07 AM
Power Source...
Thanks very much for chiming in Mark! It's really great to know that we have experts in the business like you and Mahlon (for engines) reading and contributing to the boards!
Good suggestion, but unfortunately, I've already got this square on the troubleshooting checked off - I used two diffenrt MP3 players (hoping that the first one was the problem) - a jukebox and a memory-card one, and both of them only on their battery power. Got the same whine each way. I also tried grounding the case of the players to see if that made a difference, but you know, everything is plastic these days! I can't remember who I talked with at your shop, but the suggestion to remove the jack from the airframe (to remove that ground path) sounded like a reasonable first troubleshooting step, and I haven't had a chance to try it yet. I will do that and report back!
Thanks again for joining in the loop!
(Of course, if I get htis workign, it will give me less incentive to trade up from my 6000 to that new 8000 that I've been trying to convince myself that I just have to have for the cell phone interface.....  )
Paul
Paul F. Dye
02-08-2006, 06:34 AM
Mark, I would also like to extend my gratitude for you taking the time to help others in this group. People like you, Mahlon,Stein and numerous others with excellent backgrounds in a particular area can only help us build better, more enjoyable and safer airplanes.
Welcome
Jim Wright
RV-9A N9JW 90919 SoldArkansas
http://www.jimsairplanes.com
_______________________
"It's a brutal struggle for the biscuit."
02-08-2006, 07:11 AM
May be its...
Good suggestion, but unfortunately, I've already got this square on the troubleshooting checked off - Paul
What alternator are you using? How is it wired. I am just curious? I agree with all the previous post that is sounds like a ground loop, however may be we should also start to look at the alternator itself? You do not get noise with the COM but the music you do? May be the humm was there all the time and the COM just has a better power filter.
NOISE FILTER
What about an aftermarket audio noise suppressor, aka Radio shack. You can filter the power supply to the intercom and portable device. If you are using a power converter for the portable device (14 volts to say 6 volts, they often act as power protection/filter/conditioner.)
Here is an article that Bob posted how to build the RS kit (no longer available but you can buy other kits or buy a pre-fabed filter.)
http://www.aeroelectric.com/articles...se_Filters.pdf
ALTERNATOR NOISE:
Most modern alternator are very quite electrically and expect noise free power. However you are taking AC and rectifying it with some diodes. Sometimes a soft failure of the alternator (rectifier/regulator/brushes) can result in greater ripple in the DC, which can be heard as a whine.
Next is the voltage regulator. All modern voltage regulators are electronic linear "negative feed back" type, very quite, making little electrical noise if any. Again soft failure can produce "dirty" DC.
When a semi-conductor starts to break down, there's a poor ground or if the alternator (internal or external) has a poor connection (anywhere), it can cause increased noise.
Just a SWAG (scientific wild *** guess). I know on guy mounted his alternator with some fancy plated/painted brackets, making for a poor ground to the engine. It cause some weird problems until he figured it out. Is your engine grounded well? All guessing but its a thought. The fact is your intercom is taking a very low signal and boosting it to a higher audio level to power the big headset drivers (speakers). It is no doubt taking that little noise and boosting it also. Chances are its coming thru the power/ground path. What kind of intercom do you have?
RFI
My last SWAG is it could be picking up the noise as RFI radio req interference. COM radios audio section have shielding from outside interference. The portable devices are not built to demanding spec. The wire from the portable device, thru the jack, to the intercom could pick up nose, like an antenna. Just moving or shielding these wires relative to the B-lead may help? Remember the voltages in the wires are small and get boosted by you intercom. Any small noise that you feed the intercom gets amplified with the music.
I think the other post are more likely (ground loop) but I give you my guess. To check the above remove the alternator an oscilloscope would be needed. To check the RFI you could move wires around to see if that brings relief. Last might be trying a power filter for the audio equipment.
Keep as updated. George
02-08-2006, 11:34 AM
SSHHH George!!
I'm an Internally regulated ND alternator guy, just like you George ...we dont' want to wake up THAT sleeping giant of a debate!!
I'm going to go troubleshoot this afternoon and see if I get anywhere. To be honest, this is not something I'm going to take the airplane apart to fix - everything else is so perfect that it's not worth it! It would be easier and cheaper (as someone else suggested) to upgrade to a headset with a music interface.
I really screwed up though - it is an absolutely gorgeous day here in Houston, perfect for flying, and I figured I'd go check this out in the air, but I had to go diving this morning, and now the rules don't let me fly for 12 hours....  Guess I'll just have to troubleshoot on the ramp....
Paul
Paul F. Dye
02-08-2006, 06:48 PM
No More Whining!!
Well Mark, you guys at PS-Engineering know what you're talking about! I just got back from a nice sunset flight where I pulled the Aux Audio jack out of it's mounting hole, so it had no contact with ground, plugged in the MP3 player, and got crystal-clear music.
(Of course, then my four-year-old MP3 jukebox started giving me Hard Drive errors...hey, that's an excuse to buy a new iPod, isn't it!)
The books are right...wire it per the drawings and experienced advice, and you'll likely get good results. Now I just have to run by my electronics parts place and find insulating washers for a 3.5 mm plug.
Flying Aerobatics to music as the sun was sinking low - this airplane just keeps getting better and better!
Paul
Paul F. Dye
